Question about Panasonic SC-HT930 System
Sub-Woofer One of my kids stepped on the the cord that goes from the sub-woofer to the DVD player and cracked the circuit board inside the sub-woofer. Now it won't send the information to the DVD player. Can that be fixed?
  • 682 Answers
You must replace the board with new one.
Posted on Jun 02, 2008
How to open my sub woofer for my mhc gnz9d
Subwoofers are primarily designed as sealed cabinets but it often is possible to gain access inside by removing the speaker. I once had to extract a baby bottle that some child (or adult) shoved into the port.
Nov 11, 2014 | Audio Players & Recorders
How do I connect the speakers to a sb-wa350 subwoffer
Usually, it's the "stereo-audio-output" from your amplifier that goes to the sub-woofer, and then outputs from the sub-woofer to the left/right speakers. Or, if your amplifier has a separate output labelled "sub-out", then your connect your sub-woofer to that mono-channel output.
Oct 24, 2014 | Panasonic Televison & Video
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
I puchased a pioneer vsx-820 receiver yesterday , i have a sub- woofer that only connota via speaker wire ends how can get this to work?
I have the same problem, your sub-woofer is passive and you need a powered sub-Wfr, more money is the only FIX!
Dec 16, 2010 | Pioneer AVIC-D3 Car DVD Player
The cord /with the pin on both ends that plug in the back of sub woofer & dvd player, i need the female ,plug that on the back of sub woofer
The part is called a Din connector. You may be able to find it at www.jvcservice.com You will probably need to use the sub-woofer or the system model #, it is not listed under th-c30
FYI replacing it is not very easy.
Mar 26, 2010 | JVC TH-C30 System
I just replaced the cord running from the sub to the dvd player. now my sub will not turn on
hi,
steps to trouble shoot for sub-woofer detection :
1. please check whether the cord is securely connected at both the ends.
2. check if there is transmission through the cord (there'll be a small static through the cord if there is transmission.)
3. reset the dvd-player to default audio-output and then choose the 5.1 sound system which is the correct setting for the th-c6.
4. also check the settings in the th-c6 whether it is in 5.1 mode(whether it includes the woofer-as it can also simple use the stereo speakers)
5. now check the sound output in all speakers by playing any original home-theatre system enabled dvd.
the system will work perfectly if the cord is in good condition, otherwise please replace the cord again, and this time check it at the store.
cheers
Jul 17, 2009 | JVC TH-C6 System
Need to repair my HKTS 14 Harman Kardon Subwoofer
Since this is a power sub woofer, it may have an amplifier problem that would require professional service. Yoiu can start by checking the fuse. Make sure the sub woofer is not plugged into the wall when you check it. Some of these powered sub woofers have the fuse right on the panel where the cord goes into. It may have a round cap and you turn it and pull the fuse out. If the fuse is blackend or you can see that the filiment inside the fuse it broken, you can replace the fuse with the same rating of fuse. The rating is on the metal tab at one end of the fuse or may also be listed right next to the cap for the fuse holder. If the fuse is not accesable from the panel, you need to remove panel and look for it where the power cord comes into the panel. It will be right in line with the power cord. The panel for most sub woofers are normally held on by screws all the way around the panel. You should only need to take the outside screws (around the edge of panel) off of the panel. The inside screws hold on the circuit boards, connectorsm and transformer.
If you had given more information about the problem with your sub woofer I could have given you a better answer, but with the limited information given all I can suggest right now is to check the fuse. That is always a good starting point. If you give me more information I may be able to help you much more, I have repaired many powered sub woofers but not this model. Most are very similar and can be checked with minimal effort. You would need to have a multimeter to check almost everything else with the sub woofer. Let me know if you have a multimeter and are willing to check it further. Anything less than a "FixYa!" rating is really not a good rating, so please do not rate this solution until we have had a chance to communicate more about the problem. That way I will not be given a bad rating when I have not had a chance to actually help you yet since I can not tell you how to fix your problem without more information.
Dave
Oct 14, 2008 | Audio Players & Recorders
Sub Woofer Stopped working
You know what happened to mine?
I tried to shove it behind a five-drawer file cabinet and managed to crack the circuit board inside because the power cable torqued the socket inside.
I was able to shove a tiny piece of 14-gauge wire inside and bridge the disconnect between the solder joint of the center lead and one of the metal terminals of the switch; now my speakers are working again!
Jul 17, 2008 | Audio Players & Recorders
Leads
Most of all electronics accessory or parts you can buy it in electronics shop.The leads you said is the RCA cord,input in dvd player output to home theater subwoofer.Tell the shop that you need RCA cord from dvd player to home theater sub woofer.Or you can order it in the site just type googles and search for electronics accessories.That's all jon-jon txt me what the result.
Jun 14, 2008 | JVC TH-M505 System
Connect Issue?
You need to make sure your using cable rated for use as Sub woofer don't use Audio or Digital Cables they're not the same.
Oct 20, 2007 | Samsung HT-DS1000 System
Panasonic SC-HT930 System Logo
178 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
