Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
My Raypak RP2100 will not shut down. It continues to heat regardless of the controller settings
    Genius:
  • 1,478 Answers
The controller settings is malfunctioning, the controller settings can no longer control the device, you will need to replace the controller settings before it can regulate the temperature of your device.
Take care.
Posted on Oct 13, 2010
  • 1,141 Answers
Test
How to set raypak heater to remote
hold down mode button or scroll to remote make sure wire from control system is connected to pool spa com if pool only only need pool and com
Sep 29, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Burner stays on, no control
check temp sensor if not reading that its hot enough it will keep running if ok see if not calling for heat if not gas valve sticking open replace
May 21, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
Displays HL and has been on for hours but not heating. Help!
HL usually indicates high limit which will shut down the unit. if power is turned off for a min or two it may result the fault. on some units there may be a reset button in the control unit. if it doesent reset it is most likely the hl thermal (temperature) sensor hope this helps
Aug 20, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Raypak RP2100 pool heater set temperature stuck on 50 degrees
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Jun 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
46 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
