Question about Miele 24 in. G892SCU Plus Built-in Dishwasher
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
DISHWASHER LIGHTS AND CYCLES ARE STUCK ON THE RINSE AID AND SALT LIGHTS, BUT INTAKE/DRAIN LIGHT WILL NOT GO ON. ALSO THE RINSE LIGHT ç
  • Anonymous Mar 13, 2014
    power on, stuck on dry cycle
    Champion:
  • 210 Answers
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Posted on Jun 01, 2008
Im getting an error of E24? what is this and how to fix
this is usually a drain problem. was disposer replaced? remove knockout. can you hear drain pump motor running? check filter and check valve. if drain pump is running and drain hose is not plugged, install new drain pump.
Nov 29, 2014 | Bosch SHE7ER55UC Dishwashers : Built in...
I have a John Lewis dishwasher and all the lights are on red
all the lights will be on before you select a cycle, if the Rinse Aid and Salt warning indicator lights are on you need to add rinse and salt to the appropriate fill up locations
Dec 30, 2013 | John Lewis JLDWW1200 Dishwasher
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Bosch dishwasher rinse aid and salt lights on
Are both those reservoirs filled? Clear rinse aid may cause the light to stay on, as opposed to blue or green rinse aid.
Oct 21, 2011 | Dishwashers
The salt and rinse aid lights stay on
Top up salt and rinse aid or just ignore the lights if you use 5in1 tabs.
Apr 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Flashing lights on Hotpoint FDL570 Dishwasher
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
Mar 20, 2010 | Dishwashers
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
Miele 24 in. G892SCU Plus Built-in Dishwasher Logo
1,172 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
