Question about Karcher Garden
The on off switch is not connecting. The switch just turns freely
My key turns freely
check under steering column to see if rod (linkage) is connected to your ignition switch. if still connected check if spring in ignition switch has broken (ignition switch is on steering column bottom side of column)
Aug 23, 2014 | 2001 Ford Explorer Sport
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
When turning the key in the ignition,it turns freely(in fact very loose).Then swings freely to start position but will not engage the starter. Could this be a key lock cylinder problem? Can engage the...
I would lean more towards your ignition switch being bad. Although you could be right I have not seen that problem very often. More often than not its the ignition switch. Good luck.
Feb 08, 2011 | 2005 Jeep Grand Cherokee
Ignition switch
The lock cylinder where the key goes in, does not affect your isssue. The ignition switch with the electrical connections is what you need to replace.
Jul 19, 2010 | 1995 Ford Thunderbird
1997 Ford Taurus ignition switch was jammed and would not turn. Wiggled the steering wheel and it turned. It wont start the engine but all of the dash lights are on. It turns very freely. Took off the...
the ignition switch is located under the dash at the bottom of the steering column.suspect a fault in the linkage connecting tumbler to switch.
Oct 15, 2009 | 1997 Ford Taurus
My vacuum wont turn on.
It sounds like you may have a faulty on/off switch. I suggest if you are not familiar with electricity please have someone that you know "is" to do the following. "UNPLUG" your vacuum and disconnect thee white wire coming out of the on/off switch. With a volt meter dial the meter to OHM's and hold one lead to the disconnected wire coming out of the switch and with thee other lead from the meter touch the metal housing of the motor. Click the on/off switch and if the numbers zero out your switch is good if the numbers on the meter stay the same chances are your on/off switch is bad. If the switch is good then the cost for a new motor is more than a new vacuum. Good luck
Aug 18, 2009 | Bissell 3576 CleanView II Bagless Upright...
The power switch on my PSP broke. It moves freely
You should get a new switch. Your switch broke from the inside.
Jun 10, 2009 | Sony ACY-BR81/OB
I cannot crank my coleman powermate generator.
If the engine will not crank-if it has an electric start, first check the battery and connections to the starter and ground. If the battery is good and the connections are clean and tight, then I would check the ignition switch. If it clicks once when the key is turned to the start position, check for a seized crankshaft (see below) If it does not click, then it could be the starter, solenoid, or the ignition switch. If it has a manual pull start, and it will not pull, check to make sure the crankshaft can turn freely and if not, disconnect the pull starter and check it again-if it turns freely the rope start mechanism is hung up-it must be freed up before you can pull start it. If the crankshaft will not turn at all you probably have a serious problem that will require a major teardown.
Jan 29, 2009 | Coleman Powermate Powermate 5000W...
Wipers wont work
1.  Turn on your wipers and pop your hood.   2.  If you hear you wiper motor, then you do not need to check your fuses. 3.  If your wiper arms are moving freely, then your linkage from the wiper arms to the motor is disconnected and possibly broken.   4.  If the problem is electrical, do the following:      1.  Check the fuse, and check for power at the fuse.      2.  Check the wiper motor for ground. For a complete circuit, you need power going in and ground               coming out.  Check electrical connections for corrosion or poor connections.       3.  Get a wiring schematic and trace power to the wiper motor starting at the fuse box in the                       following order:           Fuse box           wiper switch           wiper motor      4.  In the rarest of cases a wiper motor or wiper switch is at fault.  I do not recommend replacing                 anything unless you have proof that the part is faulty. (ie. power going into the switch but nothing           coming out.)
Dec 21, 2008 | 1992 Honda Accord
Garden Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
