Question about Dishwashers
Hi, I have a Fagor 1VF-453IT dishwasher and one day I switched it on - it did nothing else but all the red LEDs (5, I think) started to flash. And that's it, it doesn't run. No idea why, but I'd appreciate a hint before calling a mechanic or starting spending huge amounts for parts and repairs. Any chance for a reset or something? Thanks a lot!
  • 641 Answers
SOURCE: Ariston L63 Dishwaher problem
Unplug the power cable, remove the service panel and follow the next steps : - Remove one of the wires connected to the heating element and check with a multi-meter the element's resistance. In case you can't read any result,you should replace the element. - Check the water level switch- The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub.Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. - Control panel - look for loose wires. If you think that your main control PCB timer have failed, you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck !
Posted on Sep 13, 2007
SOURCE: won't turn on
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Posted on Feb 24, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 351 Answers
SOURCE: Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Posted on Mar 23, 2008
  • 148 Answers
SOURCE: Kenmore Elite 17262
Margaret
It sounds like something has rusted in the supply line or pump housing of the dishwasher . Running it a couple of times without dishes in it should take care of the problem When you reinstalled the dishwasher was the water supply line copper For a dishwasher only 2 years old it is hard to believe that the roblem is with the dishwasher.
If the problem continues, remove the dishwasher, replace the line from the sin riser to the dishwasher
they make a flex line that is easy to install.
Before replacing the line, pull the dishwasher out (always turn off power to dishwasher and shut off water) remove the line wher it goes into the diawasher use adjustable wrench to loosten nut
once disconnected, get a galon mop bucket put the supply line into buck and slowly turn water on under sink and fill bucket
observe the water in bucket to see if you get any debris
If so replace the supply line
While you are at it inspect the drain line from the dishwasher could be debris in it
Best of Luck BE SAFE!
Posted on Jan 01, 2009
What is this? I can't find it in the manual. I turn on the dishwasher and nothing happens.
I think your problem is with a bad contact switch. Most likely at the door. When door is closed this switch makes contact to engage machine to start. Your machine is electronic, some machines would need a lever to be moved to enable machine to be started. It all comes down to the same thing, power must flow to start the washing. You will need to look for this contact somewhere around the door. GOOD LUCK FRIEND.
Jan 18, 2015 | Fagor Commercial AD-48W Temperature...
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
Red light flashing
Hi Robert,
What's flashing? your Radio? Your Toilet? your Partner?
I need more info about your radio, before I can help you>
I need the Make/Model of your radio, without this info, I think it is the Red Leds on a cop car flashing.
Don't be afraid to give as much info as possible.
Cheers,
Peter
Dec 05, 2012 | Radio Communications
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
When I turn the set on green leds appear for about 30 sec then it swicthes to red stanby and flashes 5 times intermitently
May I know what is the exact model number of your TV, it is located at the rear cover, manual, and on the receipt. It will help diagnose accurately where the fault came from and confirm the blinking error code.
Jdvillanueva
Jan 11, 2012 | Televison & Video
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
I have an electrolux dishwasher model #=EIDW6105gS0. All lights are flashing on the console and will not let me select any of the modes...will not run at all. Is there any way to reset? I have tried...
Sorry for the delay in replying to you, but there has been a technical fault and we have not been able to answer your question.
The 6105G does not have a numeric display, so all of the LEDs flash when a fault is detected, but this does not indicate which fault has been detected. Resetting the dishwasher should clear the error message, but if there is a fault, the flashing LEDs will return after resetting the washer and further investigation will be needed to determine the cause of the fault.
You should be able to reset the dishwasher by entering the engineering test mode and then cancelling it:
1. Switch off the main power to the dishwasher or reset the breaker.
2. Switch the power on again.
3. Press SANITIZE and DELAY START simultaneously.
4. Press the START/CANCEL button to exit
5. Reset the power again.
Please try the above, then let me know if you the error persists and you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Apr 06, 2011 | Electrolux Frigidaire Professional Series...
Help
Tilt the machine 45-0 degrees and let it drain any excess water.. It also beeps when the leds flash also right? Drain the water and it will start right back up.
Aug 25, 2008 | Haier HDP18PA Stainless Steel...
7 BEEPS!!!!!!!!!!!
Please contact the Fagor America Service Center toll free: 1-877-743-2467. A customer service representatives will discuss the problem with you. If on-site service is required, they will coordinate that for you.
Jun 15, 2007 | Fagor LFA-65 IT Dishwasher
Dishwashers Logo
246 people viewed this question
Top Dishwashers Experts
Owen Barnes
