Question about Microwave Ovens
Im looking for Snail comel 721 steam iron manuals and instructions please
I have a Bosch steam iron TDS25, and the handle of the iron is getting red hot and water is coming out of the back of the iron. Help!!
Steam irons become clogged from water deposits. You may clean your iron with white vinegar and water. You should use distilled water. Make a Mixture of 1/2 water and 1/2 vinegar, and pour the mixture into the iron as you would when you fill the iron with water. Turn the iron on 'steam' and let the mixture run through. You may need to do this a few times, depending on how clogged the iron is. After cleaning use distilled water to fill the iron, becuase distilled water leaves minimul deposits behind.
May 01, 2014 | Microwave Ovens
No steam coming out of iron, does it need descaling and if so how do you do it? Thanks Iron is Wahl zx506-1
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Aug 25, 2011 | Microwave Ovens
My iron is squirting out brown gunk from the steam holes under the iron itself. i have cleaned and rinsed it out. the manual says it is a gc 7430, gc7420.
Sometimes using vinegar and water will clean out your steam iron - but smells really bad. Usually the brown gunk is a sign that there is corrosion so even if the vinergar works, you should plan on buying a new iron in the near future.
Jun 22, 2011 | Microwave Ovens
My elitech steam generator iron does not make any steam it works as an normal iron but to press the button for steam there is none???
there are 2 controls to make the steam. a dial on the base which must be turned. Then the temp must be above silk and nylon and then when you press the button you will get steam. You must have bothe the dail and the button. One without the other will not make steam. Obviously you need water too
Apr 27, 2011 | Elite Microwave Ovens
My Tefal Classic Express Steam Generator Iron is less than 1 year old. I switched it on earlier this evening and although the base unit power lights etc are on and the water tank is full, when I press the...
AS the appliance is less than a year old and you say it is a common problem, take it back under warranty to the supplier and get them to replace or repair it free of charge. It is your right after all, if you are within Europe that is.
Hope that helps.
Oct 28, 2010 | Microwave Ovens
I have a steam station Iron, it stopped sending the steam from the base into the iron through the cord .Also it has debris in the base when i empty the water Do you know the problem & can you offer...
This can be checked by you as there is not much of mechanics . Make sure that the steam is generated in good quantity so that the cord gets full pressure, if not clean the base perfectly so that there is good contact -- no debris .. make sure with a air pressure or water jet the connection tube is clean and not damaged at any points, if so the steam will not flow .
Once this is established you will get good steam pressure or else the connection tubing cord needs a change.Also make sure there are no issues in the iron to block off steam.
Sep 30, 2010 | Microwave Ovens
NEED INSTALLATION MANUAL OR INSTRUCTIONS
You may be able to download the installation instructions from the Sears parts site.
Just enter your model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpg439cb0b.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will also have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
May 17, 2009 | Microwave Ovens
Microwave Ovens Logo
379 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
