Question about Audiovox XV6700
Hard Reset How do I reset the phone? I'm giving it to a friend and need to erase all my information. I've hit the reset button...I've taken the battery out for a day or so..I've done everything. How can I reset it?
    Problem Solver:
  • 8 Answers
Hi Karen,
If you hold the soft keys down (the two that are to the left and right of start menu and ok), and press reset it will ask you to press y or n to preform hard reset.
Posted on May 07, 2009
Go to programs then go to clear data and enter 1234 and u r done
Posted on Jun 02, 2008
Lgl15g Tracfone. How do I hard reset?
With the handset turned off, press and hold the Volume Down key.
Note that a master reset will return the handset to the default factory settings and erase all personal information on the handset. All important information should be backed up before proceeding.
Aug 18, 2015 | Android Cell Phones
How to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
  • Soft Reset
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings, but there is a bigger chance that it will not. With a soft reset you will enter in *#7380#. This tends to clear any pending errors and on most phones it will help your phone work properly.
  • Hard Reset
  • The code for Hard Reset is *#7370#. Enter these digits into the phone and press yes to confirm. This will start the initialization process. Make certain you have already saved all important data. You do not want to lose your contacts, memo, or other information due to a hard reset. You may have issues with a Nokia phone that is not turned on. If there are problems such as these you can try hitting three buttons simultaneously. Hit the +*+3. If you can hit these three buttons all at once you may be able to get the phone to turn on, and then you can go through the hard reset with the proper codes.
These codes work with all of the Nokia models including the 5130. You may find other options do exist such as the power button while pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
Oct 02, 2011 | Nokia 5130 Cellular Phone
I am suspicious that my phone may have been compromised with some kind of spyware. Is there anything beyond a hard reset I can do with my HTC Inspire? I've done a hard reset but that doesn't seem...
From the Home screen, press the Menu key and tap Settings.
Flick to and tap SD & phone storage.
Tap Factory data reset.
Tap Reset phone.
IMPORTANT: This action cannot be reversed.
Tap Erase everything.
this was taken from an online tutorial for the cellphone provider i work for.
Aug 24, 2011 | HTC Inspire 4G Smartphone
I would like to give my Zire 31 to a friend but need to erase all my information from it. How do I do this?
Do a HARD RESET on your PALM ZIRE 31.
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Jun 28, 2011 | Palm Zire 31 Handheld
My HTC HD2 is stuck on the homescreen, It want let me get in the start menu to get in settings to do a factor hard reset
You can do factory hard reset for HTC HD2 even when it is turned off. But it will erase all contacts,downloaded contents and user informations. The phone settings will be reset to factory default.
These are the steps to hard reset HTC HD2.
  1. With the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it.
  2. Release the VOLUME UP and VOLUME DOWN buttons.
  3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Mar 06, 2011 | T-Mobile Cell Phones
I forgot my unlock code of nokia 6233 plz help me
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Hope i`ve helped
Nov 25, 2009 | Nokia 6233 Cellular Phone
I forget my privacy code
Well the easiest way is:
1: press menu and jump to enter emergency call
2: press and hold down menu button and while holding menu down,
press jump and back simultanously.you should enter the jump screen.
the end.
After u do that, if u wanna use the phone your gonna have to erase all the settings and do a master reset. Your going to need a tmobile sim card, and sidekick log in info to use the phone, which you should be able to get the login info by calling a T-Mobile CS agent.
Heres how u erase the flash and login info:
This is for the sidekick 2. It MAY work.
1) Remove your sim card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset now. This will reboot the device.
To perform a hard reset:
SK2 - Press the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen.
Good luck, hope that helped!
Jun 22, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Locked myself out of my mogul
You may have to do a hard reset.
You do this by:
Holding down both left and right soft keys (the buttons above the red and green phone keys) while pressing the reset button (on the bottom of your phone) with the stylus. Hol down the soft keys until you see a message asking if you want to reset. You then need t slide the keyboard open and press the appropriate key.
Warning: this will reset your phone to manufacturers settings; all data will be erased. Your phone, however, will no longer have a password, and you will be able to set a new one.
Feb 13, 2009 | HTC PPC-6800 Smartphone
Palm treo reset
You want to perform what is called a "Hard Reset"
It's pretty easy. You hold the power button while you push the reset button on the back. The treo will ask you if you want to erase all the data.
  • Unscrew the tip from your stylus
  • Locate the "RESET" hole on the back of your Treo 600
  • Press and hold the power button on the top of your Treo and then press the reset button with the stylus pin
  • Remove the pin from the reset hole FIRST, hold both for a few seconds, and then release the power button.
  • The screen will say "erase all data?", tap the up arrow to answer yes
  • Here is a explaining what I just said above:
    http://mytreo.net/archives/2004/05/hard-reset-the-treo-600.html
    Sep 22, 2007 | Palm Treo 600 Handheld
    Contact list
    you go menu,settings,security type in the four digit security code which is normally 0000,1234 or the last four digits of your number go to reset phone ,if it asks to reset phone go yes and it will come up with another message will reset to factory default go yess it will restart your phone to accept changes,another way you can do it is going to menu,contacts and going to your contacts list and just going edit but erase
    Aug 29, 2006 | Samsung SCH-a670
    Computers & Internet Logo
    283 people viewed this question
    Top Audiovox Computers & Internet Experts
    Mohammad Abumuailek
    Mohammad Abumuailek
    Greg Cann
    Greg Cann
    Martin Murray
    Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
