Question about Goodman CKL49AR49 Air Conditioner
I have an HVAC with 8 wires, and a new thermostat with 4. How do I identify which wire is what? the blower in the attic states it's a GMC. The only model number I can see says A49-20. It has an external A/C compressor.
    Scholar:
  • 80 Answers
Red is 24v from transformer to R onT-stat
Green is from indoor fan at air handler to G on T-stat
Yellow is to compressor for call to cool mode and is Y on T-stat
White is call for heat and is W on T-stat
Orange is to the reversing valve on a heat pump
Blue and or Black are used as common in most cases
Posted on Oct 13, 2010
Testimonial: "Thank you greatly for the help. I will try those and post back soon; the cold is a great motivator to fix this thing =)"
  • chrisrob1469 Oct 13, 2010
    Inside the thermostat some don't match up.
    w2= ? (white?-has a jumper over to E)
    E= ?
    O/B= ? (orange
04 iMpala LS blowr motor stopped! here are the stats: *right dash fuse was ok *big 30amp fuse was ok *new blower resistor *multifunction switch working fine *low miles on car.
Finding a wiring diagram an using a DVOM - digital volt ohm meter an testing the electrical circuit is the proper way to diagnose electrical problems . Looking at the wiring diagram for your vehicle i see it doesn't have a blower motor resistor , it is a blower motor contol processor . Electronically controlled .
HVAC Blower Motor Circuit
GMC Yukon HVAC Blower Motor Won Turn On
Dec 26, 2017 | Cars & Trucks
What could be causing my HVAC secondary circuit to keep blowing a fuse after the AC Compressor ran for 10 hours?
Yes its a short. I've seen a weakening component cause that but 99% of the time its a short. Look where your control enter your o.d. unit. The wires can rub on the metal where the small hole is for the wires to go through. If your o.d. unit has any low voltage wires inside where the piping to the compressor are, look there. A low or high pressure switch may be installed and the low voltage wires inside can rub on a copper line causing an intermittent short. Look anywhere a low voltage wire can touch anything , other than intended points. If its a component then you may end up with new parts all over and still have a short. The control wires can get damaged by varmits in the attic, crawl space, and where the wires go through the wall or sophet. To isolate it may take a pile of fuses or a transformer with a micro-breaker can be installed. Basically has a 3-5amp micro breaker that trips and can be reset. If you were to remove all control wires leading to the o.d. unit, start the cooling, and it shorts then your short is not at o.d. unit. With o.d. control wires wired in at the ahu, disconnect the low voltage wires from the o.d unit. Cycle cool and if it shorts, the wire between is the cause. If it don't short, then you know its at the o.d. unit. At the o.d. unit, if it has any low voltage safeties(low pressure, high pressure, delay timer, ect...) you can maybe bypass all to allow the contactor to be the only component wired in the low voltage circuit at the o.d. unit. And if it shorts keep chasing it. Bugs and geckos can get behind circuit boards causing a short. Ants in any components can cause a short. Hard to help more from here. Above all, work safe!
Jun 22, 2015 | Heating & Cooling
2000 jeep grand Cherokee limited only blows cold air despite c.c setting position. Also what I'm Guessing to be the blower control module hot lead burned through end of wire/ wiring harness/ and circuit...
lead burned through
that's easy
using the wrong fuse size
and the feed is shorted,
the correct fuse prevents the burned wires.
here are the HVAC pages
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
lots of things can short. in cars. (topic Hvac)
  • the wires.
  • the connectors
  • the HVAC motors (actuators)
  • the blower.
if you had stated the exact wire color and what it connect to exacty
we can state who shorted.
Fuse 1 , 40amp runs the blower. dark green.
Fuse 20 , 10amps runs others.
Fuse 7 runs zone control,,,10A and all 4 damper motors actuators.
see 8w-42-6 pages.
ok you have your FSM and now can find who connects to what.
Apr 10, 2014 | 1999 Jeep Grand Cherokee Limited
Diagram for the placement of the fan blower motor in a 2003 Dodge ram 1500 truck
From autozone.com
2003-04 Vehicles
CAUTION On vehicles equipped with airbags, disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in an accidental airbag deployment, possible personal injury or death.
NOTE The blower motor is located on the passenger side of the vehicle under the instrument panel. The blower motor can be removed from the vehicle without having to remove the HVAC housing.
  1. Disconnect and isolate the battery negative cable.
  2. Disconnect the wire harness connector from the blower motor.
  3. Remove the three screws that secure the blower motor to the HVAC housing.
  4. Remove the blower motor from the HVAC housing by rotating and tilting the blower motor as needed for clearance.
Fig. View of the resistor block screws (1), blower motor resistor (2), resistor block wire connector (3), blower motor screw (4), blower motor (5), blower motor wire connector (6), blower motor screw (7), HVAC housing (8), wire harness retainer (9), blower motor screw (10)
    To install:
    1. Align and install the blower motor into the HVAC housing.
    2. Install the three screws that secure the blower motor to the HVAC housing. Tighten the screws to 20 inch lbs. (2.2 Nm).
    3. Connect the wire harness connector to the blower motor.
    4. Reconnect the battery negative cable.
Sep 23, 2010 | Dodge Ram 1500 Cars & Trucks
04 gmc canyon replace blower motor wire harness it was fried and the resistor was fried and nothing works now after every thing was installed any solutions to what I do next ??? Please help I'm in Arizona...
Do you know how to test electrical circuits ? Look at a wiring diagram an check power and grounds . Do you have a volt meter ? You can buy them cheap enough at a parts store . Here is a web site for free wiring diagrams http://www.bbbind.com/free_tsb.html
Enter your vehicle info. - Year , make , model and engine . Under system click on HVAC then under subsystem HVAC controls . Click the search button then the blue links one at a time . Looking at the first diagram do you see the IGN3 HVAC relay #59 located in the under hood fuse / relay box ? That's where the B+ power start's ,then blower fuse # 41 30 amp. check For B+ power on the brown wire at the blower motor you should see B+ voltage on the Orange wire as well with the blower switch in the off position .Do you see how the syatem works ,get's ground through the switch .Videos on youtube on basic automotive electrical testing . check them out ,how to use a volt meter . Learn to test an not guess
Aug 26, 2017 | 2004 GMC Canyon
1995 GMC Yukon. How do you get to the heat resistor to replace it.
on the firewall of the passenger side theres a headed screws and beside it is a plug with wires, pull the plug and remove the screws. you can find a spring and you will find the heat resistor
Feb 09, 2010 | GMC Yukon Cars & Trucks
I bought a Honeywell programmable thermostat RTH2310 to replace my 10 year old Honeywell thermostat. My old thermostat is a 4 wire system but also has a jumper from Y to 1. New system does not tell me what...
It depends on the type of thermostat you have.
Do you have a 4 wire or 5 wire T'stat?
The red jumper wire was for a 5 wire t'stat with 1 transformer, the red jumper actually should have been from R to 1.
So you need to trace the wires back to the furnace and make sure they go to the locations identified below.
if you have a 4 wire t'stat then you don't need that jumper, if you have a 5 wire t'stat then you do need that jumper but it should go from Rh to Rc.
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
t'stat?
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
Blower in attic & AC unit outside continuously run
Sorry to hear about your miss-fortune, you are right it is an wiring problem. Can you turn off the blower with the thermostat (cool-off-heat) or what happens when you switch the fan to (auto or on) When you say the outside unit is "rigged" is it mechanically being jammed or electrically? If its mechanically that should be removed (what a crappy thing to do) other wise it will run continuously as you may already know. That is what it sounds like, you should just be able to shut the entire system down by turning off the switch to the furnace. If it is electrically being held closed, he changed some of the wiring around in the attic unit, you better hope he was lazy and jammed a stick in the contactor in the outside unit or else you may need to learn more about HVAC wiring, none the less I would double check the thermostat wires going to the attic furnace there should be nomenclature on the unit or at least somewhat marked. This was probably disturbed when the new blower was installed, by the way that was your initial problem. Good luck and becarful
Aug 17, 2009 | Ruud Matching Split Air Conditioner
PROBLEM
Thermostat wires or solid state control, (time delay board) sounds like your symptom.
Nov 28, 2007 | Ruud Central System Air Conditioner
Blower in Attic not running
inside unit has fan control relay , either on control board or can be separate ,except for the 24 volt transformer and the t-stat the units operate separately concentrate totally on the inside unit this is where the problem lies
Oct 23, 2007 | Ruud UAMB Air Conditioner
Goodman CKL49AR49 Air Conditioner Logo
153 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
