Question about Dryers
Top and back of Kenmore dryer feels very hot to touch
Hello, I have a Kenmore stackable electric dryer model (970-78712-10) It is installed on the side of my washer, not on top and they are not enclosed. I've had this dryer for about 9 years problem free. Today I've noticed that while the drier is working in the hot air cycle, the top is quite warm to touch. The back edge and back panel are so hot that burn to touch. I never checked this before, so it is the first time I've noticed this. Is this abnormal? I often clean the lint trap enclosure by unscrewing the vent panel so there is no blockage. I would really appreciate a comment.
  • 2 more comments
  • Lilian00 Jun 02, 2008
    Thanks so much for the response. I wonder if it could be the vent. We opened the vent half ways out and it wasn't to bad for lint. I also checked the outside end and noticed that the air is blowing out enough to keep the valve opened. I cleaned the vent with a 3 feet brush. It didn't seem to be so bad there either. Could the problem be anything else? When lift the top of the dryer open, I notice that really hot air is blowing up from the back side of the drum. I also should mention that recently I changed a foam piece in the front panel which holds the drum into place(Top half). Any other ideas?
    Thanks again.
    Lilian
  • Lilian00 Jun 04, 2008
    It's definitely not the vent. Yesterday we replaced the whole plastic vent pipe with an aluminum one. The dryer continued to feel hot even after the change! :(
  • farleycarl Nov 30, 2008
    I have the same issue, but the vent line is brand new and I took the whole dryer apart, cleaned, vaccumed, and greased moving parts. It's not a venting issue. The heating coil (in the back on our Kenmores) gets way too hot, in fact it had melted the plastic socket that holds the drum in place so I had to replace the socket. Now I run it on non heat cycles only until I solve the heat problem.
    I'm guessing either the thermostat is bad, or the emergency high heat safety shut-off, or both. Appreciate any input from someone who's solved this.
  • dummyz Jan 12, 2009
    as do i
    Scholar:
  • 110 Answers
This alway in a indication of a venting issue it would seem that it is not in your venting that you can see but it may be plugged up in the wall somewhere in this case you will need a pro. chimney sweep or THE DRYER VENT WIZARD if there is one in your area to come and clean your vents
Posted on Jun 01, 2008
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
Need test sequence for frig gleq215es electric dryer.
Hello - The following could be reasons for your dryer to stop working; there could possibly be a malfunction in the thermostat in the return, so if it gets too hot on the auto dry cycle, it stops and will not re-start until it cools down. This could be caused by either lint or something else clogging the vent thus causing it to overheat. You should be able to feel the top of the dryer right at the back of the top near the console right after it shuts off. If it is getting too hot to the touch look to the items I have mentioned. Should you find that these suggestions are ineffective, may we suggest contacting a professional to move forward accurately who will be able to diagnose the problem.
Oct 24, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Hello, I have just purchased a frigidaire gallery series stackable combo 2004 model glet1142cso after hooking it up i am having problems. It won't fill unless dryer door is open..won't spin out...
Probably an auto tec installed the recepticle on the wall or in the electric pannel. in home electric the black wire and the red wires are hot. In automobiles the black is ground. You should have 240 volts between the two flat connectors on the plug when its pluged into the recepticle.
Dec 20, 2017 | Frigidaire FEX831F Top Load Stacked Washer...
I have a Kenmore thats about 10 years old. Model No. C110-6070092....type Dr-4 stackable. It gets too hot to touch inside the back wall, so hot that I have to yell "OW!" Can this be repaired,...
I don't have that model number repair manual so went to the Sears website and plugged that model number in and it says they don't recognize that model number.
Jun 09, 2011 | Kenmore Dryers
Stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
Jan 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
1,727 people viewed this question
Top Dryers Experts
