Question about Kenmore 44072 Front Load Washer
Control Panel
Washer, purchased in January 2004, will allow selection only of the "Normal" cycle.
    Problem Solver:
  • 5 Answers
Did you ever get this fixed? I think it may have to do with the control panel or part #18 in the book which is part 134207700
please let me know....mine stays on HOT...but I finally unplugged it long enough and now I can only get COLD water. the part seems to have gone down on price so I think I will give it a try myself and hope for the best... tracyjos@hotmail.com
Posted on Nov 22, 2009
  • tracyjos Nov 22, 2009
    now I am finding that it may be the membrane panel switches instead...search ebay for parts but I am looking into #27 or part number number 134208200 which it the frame, control console with membrane ....signed, me again....tired of washing in cold only...not bad during the hot houston summers when your water is always hot anyways. LOL
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
Fafs4272lw0 affinity washer
Hello Brenda - I am more than happy to assist you! First, let's try resetting the washer machine. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit back on. Once the unit is operable, please select the Normal cycle and press one of the two selections. If the issue persists, then in the case the appliance may be experiencing a communication error with the control board, a potential wiring failure or a faulty water valve. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Jul 18, 2013 | Frigidaire Washing Machines
Display panel
Hello Thomas - I understand that your washer continues to beep and will not operate. Try resetting the unit by either unplugging or flipping the household circuit breaker off. Wait approximately two minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If the washer will not operate then it possibly have a communication error with the main control board, a potential wiring failure, or fauly door lock assembly. I would suggest contacting an experienced service technician to determine the precise cause. Thank you for allowing me to assist you!
Apr 29, 2013 | Frigidaire Affinity ATF7000E Front Load...
Maytag MDB4651AWS Dishwasher will not start.
Do you ever hear the fill solenoid click on to begin the filling. That is the first thing that has to occur. The water supply generally connects right to that solenoid. Ohm out the solenoid coil. ( breaker power off)
May 21, 2012 | Maytag Dishwashers
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Can not change Cycle setting
I wonder if it's the control board that needs replacing ??? found a note on www.managemyhome.com saying...(part no 134207700 according to my parts list). Is there anything unique/special in replacing the control board... here are the instructions for it...if you try this, pelase let me know...
Replacing the control board is just a matter of removing wires from the old control board and installing them on the new one. It is an electronic board and can be damaged by static electricity so you have to touch some ground points with you hands before touching the control board.
To access the control board remove the top panel from the washer. There are 2 screws in the rear of the washer holding the top on.
With the top removed you will see three screws going down from the top holding the control panel to the cabinet of the washer; remove them.
Lift the control panel up and it will come loose. The control is mounted to the control panel with some screws.
Oct 07, 2008 | Kenmore 44072 Front Load Washer
Whirlpool Top-Load Washer gvw9959kq
Yes. I replaced the control panel (the panel with all the cycle buttons on it). I downloaded the technician's manual from whirlpool and went through the troubleshooting to find the problem. Th part costs around $106.00. Just make sure you order the right color.
Jul 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire Washer - FTF2140FS1 - fills with water, but won't complete cycle
The water level sensor or float switch may be faulty. If the unit does not sense that the water is at the right level nothing will happen.When the water filling rate appears very slow, the inlet water filters may be clogged. Although not that common the inlet solenoid valve can jam and only partially lift.The cycle timer or program circuit board may be faulty
Jun 02, 2008 | Frigidaire Washing Machines
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 44072 Front Load Washer Logo
75 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
