Question about HP Computers & Internet
I have a virus on my cumputor - HP Computers & Internet
    Genius:
  • 3,587 Answers
Try this link for an online robust virus scanner.
it's called Housecall
Posted on Jun 01, 2008
My ipad will not trun on. tried hooking it up to the cumputor and hit both volume and on button at the same time but no luck.
I had this problem with my iPad mini. In search the web, it was said the output of some computers were insufficient to charge the device. I tried plugging it into a USB wall adaptor and after a few minutes, it powered up. If you do this, don't expect it to power up for a few minutes.
May 31, 2014 | Visual Land Prestige Pro 10D 16 GB Tablet...
Where is the cumputor located on the 91 olds cutlas
Should be on the passenger side of the engine compartment.
You would need to check for spark at the plugs and fuel pressure before looking at the computer.
Oct 09, 2012 | 1994 Oldsmobile Cutlass Supreme
Screen will not shut down when cumputor is turned off. It stays with a bright white lite. We have to unplug it from the power source.
i have the same problem i found out that you to turn off the moninter you have to either unplug it from the mains or there is a little button on the front that you press and it will turn off.
(when the computer is switched off the screen has nothing to display so it geos to power saver mode)
Nov 01, 2009 | Acer Aspire™ T180 PC Desktop
Bought a hard drive & each time I put the cumputor on it tells me I have an invalid disc & wont let me start up till I pull out the conection.
This is going to be a very general answer because I have almost no information to go on.
You computer is trying to boot off the new drive (it thinks it is C:) and cannot because it is a new drive.
If your drive are connected with a wide cable (about 1.5 inches) you have IDE drives. If your drives are jumpered as Cable Select and on the same cable, swap the physical locations of the drives. Otherwise make sure your old drive is jumpered as Master and the new one as Slave.
If they are on separate cables, the old drive should be connected to the primary controller and the new one to the secondary. Since you are having problems, swap them.
If the cable is a narrow one (about 0.5 inches), you have SATA drives and you need to go into the bios to change the boot sequence. Because I do not know the make and model of your computer I cannot be specific, try pressing the DEL key as soon as you turn on the power, this method is the most common.
I also predict that your next question after this works will be why windows does not see the drive. But, that is the next question. Right now see if this works, if not please post the make and model of the computer, the make and model of the drive and your operating system.
Oct 13, 2008 | Computers & Internet
Printer disc wont up load.instructions say to double click my computer, where is my cumputor
IF YOU GO TO THE START BUTTON AND RIGHT CLICK , GO TO PROPERTIES AND CHANGE YOU SETTINGS TO CLASSIC YOU WILL SEE IT ON YOUR DESKTOP. I USED CAPS SO YOU COULD READ THE DIRECTIONS BETTER.
When you are in My computer, You will see the disk. Double click it or right click it and look for ......... Setup.exe........
Go to Tools folder options - VIEW - then check the dots or blocks that will enable you to see ALL FILES
Mar 09, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
