Question about Cell Phones
When i open my phone ,after appearing main window and checking the phone will automatically showes Error 523 and Restart
  • 358 Answers
Hi,Anyway, with regards to your issue, error 523 reset means a "System process died" You'll need I would reload the entire hand held OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the Black Berry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
But, since this has happened so many times, I have to ask myself, is it something you're doing that it causing this? I know the Red Pearls from AT&T have had issues from DAY ONE!
Also you are having is with the phones firmware you will need to take this phone into a phone shop and have the phone flashed and the firmware re-installed, the problem with this is you can only have it done at a phone shop as they need to install all the software back on the phone and the other problem is that this will wipe the phone so you will lose anything on it. you can back it up if you have the leads to your computer and the correct pc suite for your make of phone if you don't have this just ask the phone shop to back it up for you. their is no other way of doing this as you cant get the firmware and re-install it yourself the phone shop will charge you for doing this but it will be cheaper if you go to one of those independent shops instead of one of thos bigger branded ones. let me know how you get on or if you need further assistance ok plz rate this solution as i have a whole page of unrated posts, thanks `2
Posted on Oct 13, 2010
App error 523 appears on my blackberry bold
my blackberry 8520 boots & shows uncaught exception 16>=16
app err 523 reset
i want to take a back up please help me
May 20, 2011 | RIM BlackBerry Bold 9700 Smartphone
My blackbery is showing app error 523 reset i keep pressing reset but it wont work. when i restart my phone it shows uncaught exception :index 12>=12 then again white screen and app error 523
Hi Akira,
This error can be caused by a few different things, including faulty third party software. Have you downloaded any apps lately?
Make sure you have BlackBerry Desktop Manager installed on your computer, then unplug the battery from your BB and make sure that it is not connected to the computer. Start App Loader, then plug the USB cable into your phone. Once the phone lights up, wait to see if it starts up and if the PIN appears on your computer (in App Loader). At that point, plug in your battery. The software should load, and you can remove the third party app. If you don't think it's an app causing the problem, you can try using the repair option in the Desktop Manager. Let me know how it goes.
Apr 12, 2011 | Blackberry Curve 8350i
While switch on my blockberry 8520 phone it shows app error 523 and below it shows reset but my mobile is not open at all and also its automatically on /off please find
i have the same problem the phone was working fine on sunday i charged the battery and after the reboot the error message appeared. I
Jun 28, 2010 | RIM BlackBerry Curve 8520 Smartphone
Blackberry 9630 App error 523
Hi, error 523 reset means a "System process died" You'll need to reload the entire handheld OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider.
4. Connect the phone
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
Take care
Mar 01, 2010 | Cell Phones
I have a blackberry 8130 and the app 523 error coming up how to fix it
On the BlackBerry smartphone, the following error message appears "app 523 error" after pressing the Mute button, accessing an application, or performing a hard reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Add/Remove Applications.
  4. Type your BlackBerry smartphone password and click OK.
  5. Select the check boxes next to the names of the applications you want to load.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Click OK.
  8. Click Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Jul 12, 2009 | RIM BlackBerry Pearl 8100
App error 523
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
Jun 29, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
What does app error 523 mean and and how can i fix it?
Hi your problem is solved
Error definition:
JVM 523:System process died
A critical Java process has terminated, and the device cannot continue to operate in a normal manner
Here is the resolution for your problem
Reload the BlackBerry Device Software on the BlackBerry device
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
1.Install the BlackBerry Device Software on your computer.
2.Open BlackBerry Desktop Manager.
3.Connect the BlackBerry device to the computer.
4.If prompted, type your BlackBerry device password and click OK.
5.Complete one of the following steps:
If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
6.Click Next.
7.If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
8.Select the check box for the BlackBerry Device Software.
9.Click Next.
10.If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
11.Click Finish to begin loading the BlackBerry Device Software.
12.Click Close when the software is finished loading.
Good Luck and do let me know
Feb 28, 2009 | RIM BlackBerry 7100G Smartphone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
