Dometic Rooftop RV Air Conditioner
Problem for Dometic Rooftop RV Air Conditioner
Duo therm roof top a/c
By skintknuckle on Jun 01, 2008
compressor comes on fan will not. I replaced the fan motor,it worked fine once on the test run. put it all back together tried it again, compressor comes on fan will not. Tried spinning while power was on nothing?
Comments:
Jun 02, 2008
- motor will not run when you turn it to fan. I tried spinning it will power was on it felt like some of the coils where on and some where not, motor felt like it was sticking in one spot. With power off it spins freely.
Jun 02, 2008
Same Problem
Oct 07, 2008
-   motor fan is seized. Can I replace the bearings or do I have to buy a new fan-   terpie
Sep 19, 2008
-   i have a penguin duo therm roof a/c at an rv. fan motor got hot and was spinning low. changed motor, it spins free, but will not turn at low, medium, high speed, just humms, gets hot. will change capacitor, hope this helps-   Guest
Jun 28, 2008
-   Compressor runs and fan does not. Replaced capacitor and still had problem. Checked voltage through relay board and there is 115 vac coming from both hi and lo outputs from board at the same time. Is this correct?
all fuses good. I believe camper was subjected to a lightning strike. could problem be in the thermostat?-   depdawg
Jun 16, 2008
-   the commpressor runs fan will not.replaced fan motor and run capacitor still will not run.I can hear relay click on hi position only.-   Guest
Solution #1
posted on Jun 01, 2008
Somewhat Helpful)
fixr1st
Rank: Wiz
Rating: 84%, 67 votes
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Was this helpful?
Yes
No
Popular Solutions for Dometic Rooftop RV Air
Questions and Unsolved Problems for Dometic Rooftop RV Air
Do you recommend Dometic Rooftop RV Air Conditioner?
Answer
Answer
i do not know how to work remote. i do not hav an insruction mannuel. would like to be able to turn... (More)
Answer
This is for our heat pumps on the roof. Both are doing the same thing? In the auto position on the... (More)
Answer
My ac/ heathing unit is not putting out any heat, it comes on and blowes air but the burner does not... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in Colton, CA
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
