Question about Garden
I have a band saw model mb-6 with a broken part which is bolted in behind the top pulley of the saw.its actually the part which slides up & down to tension the blade.the saw itself is a 3 pulley system.would appriciate if i could get that part supplied to me asap if possable.
  • 1,141 Answers
Test
Posted on Oct 13, 2010
How do I adjust the tension on the saw blade
there is a slide adjustment on the top roller
It is used when replacing broken bands or bands of different teeth numbers
undo the lock nut and screw the adjustment knob until the band "twangs " when flicked
do the nut up tight
Feb 15, 2016 | Ryobi Owner's Manual Model Bs901 Bs902...
Parts for a mastercraft bandsaw model number 55-6719-6 I need the two belts that go around the pulley wheels and the drive belt for the saw
Try checking www.bandsawparts.com . They have aftermarket belts for different brand of band saws.
Feb 26, 2013 | Saws
I am Looking for a miter gauge (which is an accessory) for a old craftsman model 113.244512 band saw. Is there any around out there?
You may look up to ebay or search on google. I actually order band saw parts with www.bandsawparts.com but I think they don't have the miter gauge for your bandsaw model.
Dec 20, 2012 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Belt is broken. how do we replace it?
Well you can please follow the below steps -
1. Locate the shutoff valve for the gas line behind the dryer, and turn the valve one-quarter turn by hand until the gas supply is closed off to the appliance.
2. Unplug the electrical cord of the gas dryer from the outlet.
3. Take the lint screen out of the lint screen slot on the top of the dryer, and unfasten the screws that are inside the slot with a screwdriver.
4. Place a putty knife between the top and the front panel at both corners, and lift up to disengage the plastic clips.
5. Lift up on the dryer top, flipping it toward the back of the dryer, and lean it against the wall.
6. Locate the screws inside the top of the dryer behind the front panel, and unfasten them with a screwdriver.
7. Slide the front panel forward and up to release it from the clips at the bottom of the panel, and unfasten the electrical wiring connector from behind the front panel by hand.
8. Place the front panel out of the way, and unfasten the screws on the shroud cover inside the dryer cabinet with a screwdriver, removing the cover from the cabinet.
9. Locate the idler pulley and motor in the back of the dryer cabinet on the base, and loosen the dryer belt by unfastening the bolt on the idler pulley with a socket wrench until the belt is loose enough to remove by hand.
10. Take the dryer belt off the pulleys and drum, and install the new dryer belt around the drum and the idler and motor pulleys.
11. Tighten the bolt on the idler pulley with a socket wrench to secure the new dryer belt, and reattach the shroud cover with screws.
12. Slide the front panel back over the clips on the base of the dryer, and lock the panel into place by attaching the screws to the inside top of the panel.
13. Lower the dryer top back down to the top of the cabinet, and press down to lock the lid into place on the plastic clips.
14. Reattach the screws inside the lint filter slot, and slide the lint filter back into place.
15. Plug the electrical cord of the gas dryer back into the outlet, and turn on the gas valve to restore the gas supply to the
Good Luck!!
Thanks
Mar 26, 2010 | Frigidaire GLGR642A Gas Dryer
How do I remove drive belt on 10"bandsaw
Loosen the motor mounting bolts and slide the motor forward until the belt is slack. When you replace the belt, slide the motor back until the belt is firm, but has about 1/2 " movement up and down at midpoint between pulleys. Recheck after tightening the motor.
Feb 13, 2010 | Saws
Baught belt - need to know how to chane it
YOU HAVE WHATS CALLED A TENSIONER PULLEY IN FRONT OF ENGINE , ONE OF TWO PULLEYS THAT ARE SLICK (NO GROOVES). THE TENSIONER PULLEY IS WHAT YOUR AFTER. IT WILL BE ATTACHED TO A SLOTTED BRACKET WITH A BOLT HEAD DIRECTLY BEHIND IT.(LOOKING AT ENGINE FROM FRONT OF VEHICLE ITS USUALLY ON YOUR FAR RIGHT!) FIRST UNLOOSEN BOLT ON FRONT OF PULLEY ABOUT FIVE TURNS , THEN MOVE TO BOLT ON TOP BEHIND PULLEY , AND START UNLOOSENING IT TILL PROPER TENSION IS RELEASED TO SLIDE BELT OVER ALL PULLEYS(USE BELT DIAGRAM UNDER HOOD FOR PROPER INSTALLATION. ONCE BELT IS ON REVERSE STEPS 1 AND 2. TIGHTEN TOP BOLT BEHIND TENSION PULLEY TILL BELT HAS ABOUT A QUARTER INCH PLAY IN IT UP AND DOWN (DON'T OVER TIGHTEN).THEN TIGHTEN FRONT PULLEY BOLT TILL VERY SNUG.YOUR DONE! BELT MAY NEED RE-TIGHTENED AFTER DRIVING A FEW DAYS , BUT YOUR AN EXPERT NOW AND THAT WON'T BE A PROBLEM. HOPE THIS HELPED!
May 11, 2009 | 1998 Dodge Dakota
I do not know how to change the blade on a dewalt
I'm not familiar with that particular band saw but I have had a few different band saws and they all pretty much work the same.
Unplug the saw and remove the top and bottom wheel guards.
Look behind the top wheel and you should see a large bolt standing vertically it may have a knob on it or it may not, look on the bolt to see if it has stop nuts if so loosen them then turn this knob so as to lower the wheel enough so you can remove the old blade.
Clean the rubber tires on both wheels and install the band with the teeth facing down.
Now the tricky part, adjust the top wheel so that it is firmly against the band and turn the wheel slowly by hand (be sure the saw is unplugged) if the band "walks" one way or another, you will have to find the set screw or set screws that adjust the tilt of the wheel, adjust these until the band runs true on the wheel. When it does, tighten the wheel a litte more and turn again slowly by hand repeat this until the band runs true and it is very tight on the wheel, Put the guards back on before you turn on the power. You should be good to go.
Apr 05, 2009 | Dewalt dw3988 14tpi portable band saw...
Help with my dw100 band saw
Pull the plug on the saw, take off the covers on the upper and lower wheels of the saw.
You will see an adjustment bolt above the upper wheel and below the lower wheel, with the band saw in place on both wheels turn the upper wheel by hand, if the band saw moves to either side of the wheel use the adjustment bolts to center the band saw.
Jan 29, 2009 | Saws
Proper Band Saw Blade
I was just on Sears website and if you go to the bottom of page you can link over to Sears Parts Direct and type in your model number and you should be able to get it online. Good luck
Dec 17, 2008 | Saws
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
