I have a carrier a/c 40GKX. Do you happen to have the operating manual or know a link where I could download the manual for the IR remote handset? Cos I need to do a temperature limit on the IR controller http://www.fixya.com/uploads/Images/D6F691E.PNG
SOURCE: Looking for auto restart on carrier 40GKX series
Can you please check if the remote handset is this?d6f691e.png if yes, follow below
• Connect the system to the electrical current.
• Press the button M and of the remote control and keep them pressed down for at least
5 seconds.
• The clock digits show the first configuration item (rAdr = remote address) and the temperature
digits show the default value of the respective configuration item (Ab = control of both indoor
units).
• Press the button M repeatedly until "ASt " appears.
• Press the buttons ∧ or ∨ to change the default value (OF) to the new value (ON).
• Press the button to send the new configuration to the unit.
• Press the button to exit the configuration menu.
To see other available configuration options, consult the table.
Item Viewfinder display Explanation Description
1 "rAdr" "A": remote unit A Remote address of indoor unit A.
"b": remote unit B Remote address of indoor unit B.
"Ab": remote units A and B Default address of the two units.
2 "UCFG" "HP": Heatpump Default address and heatpump
"AC": Cooling only Changes the cooling-only address
3 "UAdr" 1-240 with an increment of 1 Address of the CNN unit.
Default = 1.
4 "ZONE" 1-240 with an increment of 1 Zone number.
Default = 0.
5 "GFdn" 1-240 with an increment of 1 GFD number.
Default = 1.
6 "A St" "OF" : Shutdown mode Select the function mode after an
"On" : Automatic restart electrical power failure.
If no button is pressed for 30 seconds, the remote control automatically exits the
configuration menu and the entire procedure must be restarted.
NOTE
Posted on Apr 30, 2010
jackboy
  • 2985 Answers
SOURCE: Help
Assuming you have an XP PC you do not need software. Simply plus the supplied lead into the camera and plug the big and into a convenient USB port on the computer. Switch the camera on and wet the upload control withing a short time a screen will appear asking what do you want to do with the picture. select a folder= My pictures or create a new one. and the press next and next etc., following the instructions If this does not happen after a while go to My Computer- a new drive should have appeared called 'E' if you have the normal A C D configuration or another drive letter if you other drives active,
Posted on May 27, 2007
Slinteriors
  • 8617 Answers
SOURCE: 52HM84 previous issue and recent question links
I am checking with some of my sources at my other job to see if there is a source for the DMD panels.We are running an auto submission program to their distributors.
Posted on Jul 16, 2008
louislevel_2
  • 374 Answers
SOURCE: my LG air cond will only work when put on to manual ON
hi! there,
have you ever check the batteries,try to replace a new one.or if not function after replacing
try to clean the pads behind in any button of your remote.doing this open your remote there are quick lock in the side of your remote,use flat screw driver to loosen this be carefull to break the
lock,try to cleran the rubber pads by cotton buds
to remove oily debris and on circuit board if you have an eracer in pencil try to rub this gradually
until carbonize element disappear.then put back
pads and cover together and try.cheers and have a nice day don't forget to rate me thank's
Posted on Apr 04, 2009
motor1258
  • 6674 Answers
SOURCE: Carrier Air V in RV not working - 5 green blinking lights error
Call 1-866-464-2478, Mon-Fri, 8am-5pm. Have model numbers of lower (inside control box etc) and upper unit ready, and I'd ask for technical assistance. Good Luck.
Posted on Sep 16, 2009
Do you have user manual for I-link IR-210 Receiver?
To find the manual for your receiver, go to this link:
ManualsLib Makes it easy to find manuals online
and enter in the search IR-210. There might be different models with the same IR-210 designation.
Sep 15, 2014 | Televison & Video
Lost Remote and operators manual for SANYO DVDxDRW 1000 VHS and DVD combo RECORDER
Hi, Download IR Remote software and use your cell phone as remote controller.
Apr 20, 2014 | Dell (1000-DVDCDRW) CD-RW/DVD-ROM Combo...
How do you know remote is working?
Fresh batteries in remote? Will AC turn on by manually at ceiling assembly? Little green or red light on at ceiling assy? Have you checked Carrier site for manual to download?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
DISH Social Media Representative
Jan 16, 2013 | DISH Network ES161256 21.0 IR / UHF Pro...
Need to know code to operate my sony blue ray with my dish remote 20.0 ir
The top 7 codes we have for Sony are 629, 671, 898, 888, 919, 778, 500. The link will have more codes to try should those not work.
Remote Codes: http://www.mydish.com/support/apps/remotecodes.aspx
Tommy Faust
Feb 28, 2012 | DISH Network IR Remote Control
5 seconds.
units).
Default = 1.
Default = 0.
Default = 1.
NOTE
Feb 19, 2010 | Carrier Heating & Cooling
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
Onkyo DVD player - remote doesn't function at all
One of the two things might have happened:
- The IR sensor got covered - by some reason
- the IR sensor talks to a small controller back - which is not working at all.
Dec 17, 2008 | Onkyo DV-S525 DVD Player
Heating & Cooling Logo
2,765 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
