Please can someone tell me details about the pump motor on the WFB 2005 AU It has a 220-240W 50Hz 30w 0.2A spec. and looks like what i would call an inductoin motor. The electro-mag field magnets are semi exposed and fit closely around the plastic housing for the rotor; the rotor spins inside this housing with a small clearance (about 1.5mm). There are no electrics exposed in or around the motor I have the motor apart and have re-bushed the bearings; but the rotor chamber appeared to have been wet inside. Nothing had failed totally yet!!! QUESTION: Is the rotor chamber supposed to run wet or dry? QUESTION: Does the small washerlike seal between the rotor and impeller need to be perfect or not so?
  • 4 more comments
  • jpchapple Oct 13, 2010
    Yes the washing machine is about 10yrs old, it is a Bosch WFB 2005 AU (The AU is just their code for Australian, that is 240Volts) ; it is a front loader.
    I am repairing the pump because it was noisy; the impeller and the rotor shaft were loose ( about 1.5mm or -). Too much!! I like fixing things. Also i am not wanting to pay say $175 all up for another pump for what is an old machine. It did pump ok, perhaps 75% compared to new.
    The machine is Australian, I am NZ. I like fixing things, the pump was noisy, and perhaps working at only 75% efficiency. I am not wanting to spend $175 all up for a new pump, for what is really an old machine.
  • jpchapple Oct 16, 2010
    Thank Luisa, I understand your response and shall now endeavour to find a suitable seal.
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now the model number of your machine confuses me,could you tell me the brand of the machine and if it is a front or top loader?Looking forward to your reply.
Posted on Oct 13, 2010
  • luisa_sgro Oct 13, 2010
    Hi just been thinking about your machine .The pump you are describing is a synchronous pump.If you are in Australia as your model number suggests then the generic pumps for your machine are quite cheap.Sorry to ask you this but why are you repairing the pump?Is it not pumping properly?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
    Hi just read your last posting.Now on the questions asked the rotor chamber usually should run dry.The rubber seal around the shaft is supposed to be nearly perfect.The problem with these pumps is they sometimes develop an intermittent fault of working then next wash they don"t work until the impeller is manually shifted to another position. Hope this was helpful and please reply for further information or advice.Good luck.
Bosch WFB 2005 Pump Cover Stuck
You can replace the pump and not have to buy a new machine.
May 19, 2012 | Washing Machines
Philips tv 14pt 50Hz block
Hello
Will you please give me some more details about the fault to your tv? What do you mean by this '50Hz Block'?
Provide some more details please.
Feb 27, 2012 | Televison & Video
Why won't the windshield washer motor and fluid pump work on my 2005 Magnum SE? Turn signals work fine, but no washers. #18 fuse is good, too. Please help
could be the washer motor. have someone hit the switch while you listen at the pump to see if it is making noise. also check to see if you have voltage at pump. it could be stuck or corroded.
Jan 02, 2012 | 2005 Dodge Magnum
What kind of motor oil for my equinox 2005, and how much.
Use any major brand 5W-30W spec oil. In hotter climates you can also use 10W-30W
Mar 07, 2011 | 2005 Chevrolet Equinox
Hi there I have a bosch wfb 2005 with a drum that doesnt turn at all. It turns/spins freely by hand & is quiet but whether with or without water in it, it doesnt turn at all! Made a lot of noise on...
hello the belt could have snaped if ok check the brushes on the motor 2 plastic blocks either side of each other hope it helps
regards
shaun
Jan 04, 2011 | Bosch Washing Machines
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
