Question about Car Audio & Video
Manual for tma 1000.1amp - Car Audio & Video
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
May 05, 2012 | HP 4570C Flatbed Scanner
Hp scanjet 4670´s tma does
I'm afraid there are no drivers running under Windows Vista for this unit.
If you have the W XP install disc , you could install a virtual version of W XP on your HDD (
http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 )
You could also partition your HDD (
http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one .
Dec 31, 2010 | HP ScanJet 4670 Flatbed Scanner
Whats the difference between jl audio 500.1 amp & jl audio 500/1v2? why is the price range so different?
500/1 is JL upper line, and the 500.1 is their lower line. They also have another line altogether that is under a different brand name.
Sep 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
Scanjet g4050 TMA lamp does not move upand down lid
Sorry to say, there is no solution to this fault. HP are not interested in it (even though I have proof, in a faulty slide copy, that it was there before the warranty ran out), Amazon ignores me. HP offer an exchange scanner which costs more than the original. Complicated story
Jan 26, 2010 | HP Office Equipment & Supplies
I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
Jul 02, 2009 | Office Equipment & Supplies
Multible amp wiring
Its always a better idea to use a distribution block when splitting your power source to multiple amplifiers-but you asked if it would work not what a good idea is -so to answer you yes it will work -im not recommending it but sometimes ya gotta do what ya gotta do
May 22, 2009 | Kicker CVR12 Car Subwoofer
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
Virus scan starts but never gets beyond 0%
First thing you can try is to disable/shut down the Spysweeper and then try scanning with TMA.
If that still doesn't work, I would uninstall the Spy sweeper and try scanning with TMA.
If that still doesn't work, uninstall TMA, and then reinstall the TMA.
Most A/V do a scan during installation. Watch to see if it works.
After reinstalling the TMA, make sure you run its update program (if it didn't during installation) and then run another scan.
Oct 21, 2008 | Trend Micro Antivirus 2008 for PC...
Tma problem
Light in cover had failed,fitting a new cover solved problem.
Sep 02, 2008 | HP ScanJet 3970 Flatbed Scanner
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
