Question about Sony Playstation 3 (PS3) Console
Hi, I have recently moved abroad and I have plugged my PS 3 into the TV using the HDMI cable. When I power on the PS 3 I get no sound or picture however when I insert a disc the game will fire up and everything operates fine. The only problem is that I can not get into any of the setting menus and therefore can not update my internet settings and connect to the internet. Even when I press the PS button I get the menus but when I click on internet set up and it says it will leave the game and go back to the main menu, when I do this the screen just goes blank. Please help.
  • Sony Master
  • 6,993 Answers
First, use another method of connection, that is, use RCA (Yellow, White & Red) and try again. If thata doesn't make any difference, then try the below steps/method:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Posted on Oct 13, 2010
Having issues setting up the PS4 can't find the hdmi slot same size as the hdmi wire that comes with the console. Hdmi wire and tv shown in pic
  • Connect the included HDMI cable to your TV and the PS4's HDMI Out port Connect your console to your cable or satellite box Unplug the existing HDMI cable connecting your cable or satellite box to the TV and plug it into the PS4's HDMI In port Plug the PS4 into a power source Power on the PS4 Plug the controller into the PS4 using the included Micro USB cable Press the PS button on the controller to pair it with your PS4
Jan 10, 2017 | The Video Game Consoles & Games
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
I have just purchased a 46" samsung led tv @100hz
Try resetting the entire video/audio settings to default. The blur on the picture may indicate that your motherboard is going bad. Recently there was a customer who had the same problem. It was his board. When we tried the AV cables, the blur went away. We tried different HDMI cables and the blur was still there when using HDMI output. It wasn't the TV, and it wasn't the HDMI cables. It was the board going bad.
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
My ps3 will turn on but wont show a picture on the tv or give sound
Reset the video settings by turning on the ps with only the power cable plugged in, when turning on continue to hold the power button until you hear a second set of beeps then turn off the console.
Boot up the ps and plug in your av/hdmi cable and you should have picture and sound.
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
I turn on my playstation and it works but i got no picture or sound. Recently i took my playstation to a mates place. my tv is standard def. my mates is high def 1080p. when i connected my sony to my mates...
sometimes ps has this problem as i m also havin a ps2 n ps3 n i play them on my standard definition tv ....i also hav to restart again n again till 10 to 12 times then finally it starts this may be a plate problem go show it to ur nearest service center.......hope it works
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont work with AJAX after using HDMI cable
ps3 does not reset the video automaticly you have to reset it yourself any time you go from one mode to the other
to do the vid reset just hold the power button when in standby(red light) untill you hear second beep then release
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
PS 3 20 GB no picture,
Is your yellow cable plugged in ?, maybe its broken.
or maybe you need a coaxial cable or an s-video cable.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
