Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Question
Our machine has stopped working and we are unable to remove the brew group. It appears lodged in the upper left hand corner and we are afraid to force it out. I saw you were able to offer help re: this machine on the FixYa web site and hoped you might have some thoughts on our problem, too.
Thanks in advance for any suggestions.
  • mommarazzi Jun 02, 2008
    Dear Dutchman05,
    Thanks for your prompt response. We had tried both those approaches...it is really stuck. Some flat piece from the brew group looks as if it's rotated downward on the upper left side preventing the dump box on the drip tray to be inserted back in place. Any other ideas? I've pulled pretty ******* it but am afraid I'll break something, or perhaps I already have.
    Thanks again.
    Mammarazzi
  • 487 Answers
Ok. Sometimes saeco has this problem and it can be a pain.
try unplugging it and plug it back in and turn it on with the door shut and all trays in position.
Sometimes it unlodges itself.
If this truely does not work :
remove dreg tray and push the brew group with the button (lever) pushed to the right inward. And now with the lever to the right still start wiggling while pulling outward. It can take a little but this should work. Don't be afraid to put a little force into it.
Check this SAECO or SAECO MANUAL
Let me know how you made out
Posted on Jun 02, 2008
  • eric bosman
    eric bosman Jun 03, 2008
    Hi mommarazzi,
    What happens sometimes is that the dreg scraper is lose when you put it in.
    There is one thing you can try.
    There are 2 sensors in the back wall. One where the door extrusion fits and one where the lip of the dreg tray goes in.
    This is a 2 man job lol stick a thin either wood or metal piece in either slot. then turn power on. Lights will go of( the red) if inserted right. hope this will work to reset the brew group.
    If this does not work force the dreg scraper back in place by pushing it toward the brew group to the right.
    let me know how you make out
Saeco incanto classic
http://www.partsguru.com/SaecoIncantoClassic.html
Apr 24, 2014 | Saeco Incanto Classic Espresso Machine
I have a Saeco Incanto Classic. There is hardly any water coming through the coffee dispenser even if I only use the preground doser without inserting coffee. While the little water comes out it makes a...
Sounds like the the shower screen under the red o-ring in the brew group needs to be cleaned, you can remove the screen and clean or you can purchase some espresso machine soap puro caff or puly caff, and run it through the brew group using the preground method the clean out coffee oils.
Aug 26, 2011 | Saeco Incanto Classic Espresso Machine
The brew group is stuck half way thru the brew cycle and now it won't finish making or dispensing steam. How can I unstick the group?
Hello Teresa,
I understand that the brew group is stuck in your Expresso Machine. Did you know that it has to be removed and cleaned ever so often. The users manual explains how to reset and remove it for cleaning. Incase you no longer have the users manual here is a link to the users manual http://www.cerinicoffee.com/custompages/Manuals/Saeco/IncantoClassic_Manual.pdf
Thank you for using FixYa.com
Justin
Mar 11, 2011 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto - Brew group does not go back into place
Put in the driptray and dregs box to the machine, close the door and power on the machine. When the machine not get any noise more, open the door and take out driotray and dregsbox. Put the brewing unit on place and the same with the driptray and dregsbox.
Best regards
/Mirran
Oct 19, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Removing the brew group
Directions on how to remove a jammed brew group: http://cerinicoffee.com/Saeco_technical_documents.asp
Shop for Saeco parts and cleaning supplies: www.cerinicoffee.com
Jun 01, 2008 | Saeco Incanto Classic Espresso Machine
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
No coffee coming out of the machine!
First step, increase the grinder size. Note: only change grinder setting while the grinder is spinning. If that does not work, look into cleaning your brew group screens. The machine should have came with a key to remove the screen. If your machine as a preground option try making a preground coffee without inserting coffee to see if only water will come out. If water comes out then you know its your grinder. Usually too small of grinder sizes will stop water flow.
If you need a brew group key:
http://cerinicoffee.com/Saeco_Brew_Group_key.asp
Espresso machine Cleaning supplies:
http://cerinicoffee.com/Coffee_cleaning_supplies.asp
Dec 01, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
119 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
