Older projection tv
Tv has lost clarity and has a dark picture
  • 5 more comments
  • dpljr Jul 09, 2008
    Over time my picture has gotten dimmer and the colors have become rather washed out. Tried adjusting, with unsatisfactory results.
  • TonyT33 Sep 25, 2008
    I have the same problem. When watching a movie or TV show where the scenen is dark, like at night, you cannot see hardly anything.
  • grapeape223 Oct 28, 2008
    My tv is about 8-9 years old & getting dark (I also can not see a thing when it is a dark scene). I very lightly wiped the bulbs off & the clarity seemed a little better afterwards, but still dark.
  • Anonymous Jan 31, 2009
    All of my pictures are too dark.  I've tried the adjustments and it is still dark.
  • there_is_no_ Feb 09, 2009
    Same problem for me. Dark scenes are poor. I cranked up the brightness just to play some video games. I opened my set up and cleaned the mirror and the 3 lenses. It helped some, but I'm still disappointed. Any advice out there?
  • cherdons Mar 03, 2009
    The picture is too dark. Can anyone help? We have the brightness turned up 100% Cheryl
  • billboard195 Apr 22, 2009
    My tv is 10 yrs old dark and fuzzy picture
Slinteriors
  • 8617 Answers
SOURCE: My Panasonic HDTV Projection Monitor/TV
THe coolant in the CRTs most likely needs to be replaced. this is a very common problem in Phillips and magnavox rear projection TVs.
Posted on Sep 11, 2008
  • 668 Answers
SOURCE: dull dark picture on kdf-e50a12u rear projection
Depending how long you have owned it and if a Lamp was ever replaced, it probably needs to be replaced. You can check with SONY at
1800-222-SONY and see if they could sell and send you one.
Hope this helps,
Skyassoc
Posted on Jul 21, 2009
SOURCE: Philips-Magnavox 9P5534C103 55IN. PEAR PROJECTION
TV does not display picture on whole screen....it has three smaller colored rings with the picture inside of it
Posted on Sep 06, 2009
Seth Wolf
  • 12 Answers
SOURCE: dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Posted on Feb 02, 2010
  • 171 Answers
SOURCE: DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Posted on Aug 20, 2010
Mitsubishi 60 dlp 120hz tv picture is not as bright as before
have you checked your connections and sure your getting a HD signal for the clarity . as to Darkness it may be a lamp failing and that also may be your clarity problem if its getting to the end of its life span on the bulb
Oct 19, 2014 | Mitsubishi Televison & Video
Color settings for an older panasonic tv trying to adjust the color setting for this older panasonic tv, it seems the dark colors are really dark and there faces are really red. Model# CT-32g19j
This is not a projection set; but a picture tube set or CRT (Cathode Ray Tube) technology. If the set is working correctly you should be able to go into the menu and set the color, brilliance and contrast to get the right color and picture intensity. If the controls don't give you what is correct viewing it may be over age and need an adjustment of the internal chroma circuits - which may cost more than the set is worth since it is quite old. Hope this helsp.
Oct 08, 2014 | Televison & Video
Picture is dark. cleaned the lens and tried to adjust brightness
have you changed the bulb. over time it will go dark as the bulb burns out...
Oct 21, 2013 | Mitsubishi WD-73C9 73" DLP TV
Dark picture
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
I have a Samsung HCN5529W projection tv. The
yeah plenty, on older rear projection t.v.'s the circuit boards tend to over heat as they get older. keep the t.v. off and unplugged. contact a local repair shop.
Feb 20, 2009 | Samsung HCN5529W 55" Rear Projection...
Jun 01, 2008 | Televison & Video
Too much red and unclear picture
sounds like your red picture tube (CRT) has developed a short. You will need a new CRTthey are very exspensive if they are still available. However I have a source for used Phillips picture tubes if you would like me to post a link. Let me know.
May 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Dark Picture on my 5 year old 42H81
Any horizontal or sqiiggly lines in the picture or just a loss of light level?
Nov 07, 2007 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
414 people viewed this question
Top Televison & Video Experts
