Question about Lanier UNKNOWN
I have a problem with my navigon 5,when i start it tells me that i have to register the device,but when i go on line to register,it tells me that the device is already registered(which i did about a year ago).My manager at work(a geek) says its me,is he right?
Navigon softwear cannot be started
Posted on Nov 02, 2010
How can y dow the sofware and instal on may navigon cg 2026
See the website, you can download a fresh install of your maps.
Probably you need to register first.
NAVIGON MN8
May 03, 2014 | GPS
It only shows Restoring factory settings and cannot switch it on or off
With the help of NAVIGON Fresh you can reinstall the software and thus return the device to the factory state. This can be necessary when the device does not work properly anymore or when the software freezes, crashes or otherwise does not behave as intended.
Please be advised that after reinstallation your saved data and favorites will be deleted. After reinstallation a software update or reinstallation of maps can be neccessary as well.
In order to reinstall the software and return the device to the factory state follow the steps detailed below:
1. Check if your device is on the compatibility list for the device restore
process.
2. Charge your device fully with the car or home charger.
3. Connect it via USB cable directly to your PC and turn it on.
4. Start the NAVIGON Fresh program and log in to your account with your
email address and password.
If NAVIGON Fresh is not installed on your PC, you can download the
software here.
5. Go to the menu bar at the top window border and click on
"My Navigon Device" and "Restore Device".
6. If NAVIGON Fresh does not recognize your device, please contact the
service center.
7. Follow the instructions and choose the device which you want to restore.
8. When the wizard has lead you through all the steps, click "next" to
begin the device restore.
9. As soon as the device restore has successfully finished, check for
updates for your device and install them.
Jun 03, 2011 | Navigon GPS
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
Navigon 7100 need activation code key for fresh maps
Activation cord is in the freshmaps activation card that comes with purchas of device.It is on the back of the card remove plastc with nail and you will get 15 digits number in 3block with 5 digits each.
May 05, 2010 | Navigon 7100 GPS Navigator GPS Receiver
Navigon software cannot be started. Please reset your device. Thats the message I get when I turn my navigon 2090S on. Can I get help
there is a reset hole somewhere on there that you could fit a paperclip in, click on that for 5 seconds and it will reset your device for you
Dec 29, 2009 | Navigon 2090S Car GPS Receiver
I have navigon 7100. Whenever I inputted information it takes a long time to response despite having a signal
That is typical of navigon. Based on Consumer Reports, it is THE slowest GPS to sync and recalculate...on the market.. Up to 5 minutes on some tests....
Nov 27, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
I am going to maui and oahu i need a map for my navigon my current map only works for us and canada
http://www.navigon.com/site/us/en
If you go to this site and register your product, you should be able to download the maps you require.
Thanks,
Jim
Aug 04, 2009 | Navigon 7100 GPS Navigator GPS Receiver
NAVIGON 2100 won't move as I go down the road.
garyboop1 Try just rubbing you finger accross the screen, it should give you some result. Rusty1
Dec 31, 2008 | Navigon 2100 Portable GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Lanier UNKNOWN Logo
Top Lanier Televison & Video Experts
Electro Med Services...
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
