Question about Hoover Washing Machines
Machine vibrates & bangs very loud when spining
  • 413 Answers
Is it new? Have the shipping bolts been removed in the rear?
Posted on Jun 01, 2008
Kenmore 80 series spin cycle isn't spining water out
could be defective part or lid switch problem
Dec 10, 2013 | Kenmore Washing Machines
WMA30 Front loader
when a machine gets old it is always normal for the vibration and banging to occur, then, after the vibration it settled down smoothly.this is due to worn fan belt .bearings worn out and the preasure on the spindle.so dont get alarm .but you will soon have to replace the washer as the banging and the vibration will get worse eventually.or change the fan belt.and replace bearings.which can be done by a qualified personel.good luck.
Jun 09, 2007 | Hotpoint WMA30 Front Load Washer
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Vibrating when spining
An underloaded machine can get out of balance because there's not enough clothes in it to shift around evenly. Don't do small loads. Check to see if a drum spring has broken, you may have to pop the top to see. A putty knife at the top front corners will release the spring catches for the top.
Apr 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Loud banging noise commencing spin operation.
one or two of your dampners are either lose or broken.
Open machine and check all dampeners . replace the roken ones. Dont use the machine as it will increase damage
Jun 22, 2008 | Creda W100FW Front Load Washer
Washing Machines Logo
151 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
