Question about Panasonic DP-C263 Copier
How cn i solve machine error 720k pm required?
720K PM Required
This error is associated with the self test the printer does on the print head during power-up of the printer.
it is indicative of either a faulty print head or a faulty main control board, neither of which are easy or inexpensive to replace.
Sep 23, 2016 | Panasonic DP-C354 Copier
How do I fix an x-pm brother 4000d error
Call the Brother toll free service line
Dec 14, 2014 | Brother Sewing Machines
Malfunction error PF-PM on Brother Innovis 4000D. HELP!!!
try unplugging it and letting it rest for 20 minutes? Sometimes that will reboot it.
Dec 10, 2013 | Brother InnovIs 4000D Computerized Sewing...
How to reset panasonic kx-mb772
call service 17 in panasonic MB-1500
Dec 13, 2011 | Panasonic KX-MB 772
During reheat and popcorn settings - the error code F4 appears
Hi hoodrd,
If you are encountering F4 error code from your Amana oven this is because you have an Open Oven Temperature Sensor. This error requires a replacement of new oven temperature. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
Jan 17, 2011 | Amana ACO1860 Microwave Oven
Error 990
sc990 is a general software error and could be caused by a number of things.
Is the copier very dirty, or are the PM (preventive maintenance) parts past their recommended counters? The copier may just need some new process parts (drum, charge roller, developer, etc.) and a good cleaning.
Does the 990 happen when you are printing or scanning? It could be an error with how the machine interfaces with your network.
Or, it may be a system firmware issue and the firmware needs to be updated or flashed.
Jul 05, 2010 | Ricoh Aficio 2035 Copier
We were installing a panasonic strada cn-nvd905u it was working fine untill we disconnected the battery to install amps after we disconnected the battery it reseted the panasonic unit now its asking for a...
1-800-211-PANA (7262),
Monday-Friday 9 am-9 pm; Saturday-Sunday 10 am-7 pm, EST.
If you forgot the code, the unit is ussless without it and can only be changed if you know the code. Try the number above for more assistance.
Jan 25, 2010 | Panasonic Strada CN-NVD905U GPS Receiver
I need a JU-253-403P floppy drive or equivalent
[International Portal Floppy Drive , www.ruanqu.net] is "TEAC low-density jumper floppy drive, SONY low-density jumper floppy drive, YE-DATA low-density jumper floppy drive, EPSON low-density jumper floppy drive, MITSUMI low-density jumper floppy drive, Panasonic low-density jumper floppy drive, Mitsubishi low-density jumper floppy drive, CITIZEN low-density jumper floppy drive, NEC low-density Jumper floppy drive "global distributor. ]
Mar 05, 2009 | Panasonic (JU257A607P) (JU257A607P)...
Epson smd349 floppy
Hi Elia, Could be a couple of things: -Your drive may only be a 720K drive. They will format 1.44 MB disks but only with a 720K format. The test is inserting a HD disk and try formatting it as HD. -The disk could be mislabeled, HD disks have two holes on end opposite the slide, one to write protect the disk and the other to signal to 720/1.44 capable drives this is a HD disk. -The HD disk could be formatted as a 720K disk even though it is an HD disk, reformat as HD. -The new, used drive could be damaged. -The drive could be configured as a 720K by the computers BIOS. You?ll have to enter the BIOS setup find the config for the A drive and set to 1.44MB. Let us know what happens and please don?t forget to rate the posting.
Jan 19, 2007 | Epson 1.44MB 3.5 Floppy Drive Floppy Drive
Panasonic DP-C263 Copier Logo
50 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
