Question about Sharp R-403HW Microwave Oven
No heat or turntable motion
Hi... i was boiling some water and had the microwave set at 5 mins. with about 1:30 mins to go the microwave fan and turntable stopped working.
the timer and light still work... just not the turntable and fan. i've noticed that if i press upwards on the door and hold it, everything starts working as normal... if i let go, the timer continues counting down and light stays on, but that's it.
the door looks fine, cosmetically speaking... so what could be the problem?
  • Sharp Master
  • 9,086 Answers
This is usually caused by either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383 or here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
My microwave oven siows down and then speeds up.
Is it still heating food properly? You can perform a basic test with a microwave safe mug or plastic cup of water. It should be boiling or too hot to touch within 1 to 2 minutes. Be careful not to overheat the cup if plastic and use extreme caution when touching or removing it from the microwave.
If it is not heating properly then the magnetron may be faulty and unit should be replaced.
Can you tell what specifically is speeding and slowing? Is it the turntable or the humming sound of the unit itself? Many microwaves vary their intensity in order to heat/cook evenly and that will vary the pitch of the sound you hear and sound like it is speeding up or slowing down. If the turntable is slowing and speeding up then there may be a bad motor and the unit should probably be replaced.
If the unit is heating adequately and the turntable speed is uniform then what you may be hearing is simple power cycling and/or fan noise.
Only trained and certified technicians should attempt repair of microwaves due to the hazards of high voltage and microwave radiation leakage if parts are not replaced properly. Although you can have a microwave repaired the cost may be equal to, or higher than, the cost of an equivalent new unit for a 900w microwave.
Feb 28, 2015 | West Bend 0.9-cu. Ft. 900-watt Microwave -...
How to make rice in mwg9115sb?
I hope this will help I have a Panasonic which it gives you a guide for rice :
Basmati 250g low 10-12 mins
Easycook White 250g on High
Use 600ml (1pt) to 800ml 1 half pints boiling water. Cover and place on turntable.
May 31, 2014 | Emerson MWG9111SL Microwave Oven With...
Heating problems Jenn-air microwave - jmv8000bds - it heats while unused for a while but to warm more than the first item is not working - what is broke? jeffrey40@yahoo.com
First, check to make sure that the air vents are clear. Secondly, is the cooling fan running? If these are OK, (how old is this unit?) it's probably the magnetron is old and weak....... Put in a container with 2 quarts of cold water and run it for 10 minutes. It should boil water after about 4 or 5 minutes and keep boiling it for the remainder of the timer preset. If not, the magnetron is losing power.
Sep 20, 2013 | Jenn-Air JMC8130DD Microwave Oven
Microwave quite heating. Tried cup of water, but not heating. The fan is running but sounds abnormal. The lights are on and the turntable moves.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 20, 2010 | Dacor DCM24 Convection/Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Kenmore microwave Model 72 8975590 (750 W) is taking longer to heat food. Takes 3.5 min to bring one cup water to boil, previously took 2,5 to 3 min. Does the element lose power over time?
I can adjust the power level so that circuitry seems to be ok. The longer water boil time could be partially due to the colder winter temperature of the inlet water. We'll just cook the food a bit longer as long as the magnetron is still working.
Jan 21, 2010 | Kenmore Microwave Ovens
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Lights up counts down and thats it no fan no spin no heating
I believe that there are to fuses inside this unit. One feeds the electronic components and the other feeds the turntable and the magnitron. Un plug the unit and check both fuses, you might get away with this cheaply. Please let me know if this helps. P.S. if one of the fuses continues to blow its time to get rid of the unit, because if they go bad they get stronger and very dangerous. What normally would boil water at 3 minutes could change to 45 seconds. Be careful.
Aug 13, 2009 | Zanussi ZM24ST Microwave Oven
Sharp R-403HW Microwave Oven Logo
97 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
