Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
The tower of lights on the right hand side of the control panel the top one flashes and the washer stops mid cycyle. have tried to unplug and reboot without success
  • info65326 Oct 13, 2010
    This is for a Hotpoint WDL520 we orignally cleaned the detergent holder and replaced it, tried to do a wash and the washer stopped mid cycle with the top light flashing, tried to unplug for 1 minute as the manual suggested, it worked for about 5 minutes then the top light started flashing again and did nothing more??
  • 11,896 Answers
While left unplugged for a few hours, can you press and hold the stop or cancel button for 10 full seconds, then wait half hour before plugging it back in. This is a hard reset.
Posted on Oct 13, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the issue is with control going bad however, before replacing the control try to reset it. To reset it you'll have to press and hold the TEMP and OPTION button for 10-15 seconds. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Oct 13, 2010
    OK then please
    check that the drain hose is not clogged with debris and any other foreign
    object(s). If it is clean then the timer has gone bad and needs to be replaced.
    Please do accept the solution if the issue is resolved or post a comment for
    further assistance.
    Thanks
    Rylee
    OK then please check that the drain hose is not clogged with debris and any other foreign object(s). If it is clean then the timer has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
The "Control Locked" light is
unplug the washer,remove the lower panel, get hand under the front panel on right side and pull a level while pulling the door open. put back together the lower panel.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I havde a top load washer . sometimes it doesnt start the wash cycle because its not recognizing that the top is closed. swe have to press on it most of the time for it to start .. but someetimes it stilll...
The lid switch is mounted to the top on the right hand side. First unplug unit remove the control panel one screw in each back of each end panel ,remove main retaining clips and pivot entire washer housing to gain access to internal parts..Also check hinge screws (2 small phillips head) on each side of lid ..the arm on the right side actuates the lid switch if loose could cause intermittent operation
Nov 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Stops working, begins beeping and f dl starts flashing. Have unplugged and replugged several times but it won't release door
Hi
Thanks for using FixYa. Error “dlf” or "F dl"means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Kenmore Elite 45986 Front Load Washer
It keeps stopping and flashing DL F
Hi
Thanks
Rylee
Aug 21, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Whirlpool duet washer and on the control panel the light that says control locked is on and the washer does not work - is there a way to reset it?
Press the Pause/Cancel button twice then press and hold the End of Cycle Signal button for three seconds until the Control Locked light turns off. If it doesn't work, unplug the washer for at least fifteen minutes to reset it.
Replace the user interface/LED assembly if the Control Locked indicator still lights up and not allowing you to operate the washer.
Remove the three screws at the rear of the top panel securing it to the back of the washer. Slide the top panel back and lift it off the washer.
Disconnect the user interface/ LED assembly ribbon connector from the left side of the central control unit (CCU) and release it from the wiring harness brackets.
Pull the dispenser drawer out and press down the release tab at the back of the drawer to pull it out completely.
Remove the screw that was covered by the dispenser drawer in the recessed hole next to the drawer opening.
Open the door and insert a flat-bladed screwdriver into the notch at the bottom center of the control panel to release it.
Press and release the tab behind the right hand side of the control panel securing it to the cabinet.
Gently pry up and release the top of the control panel and pull it off the washer.
Pull the cycle selector knob off the control panel and release the tabs securing the user interface/LED assembly to the control panel. Lift the user interface/LED assembly from the control panel once all the tabs are released.
Install the new user interface/LED assembly into the control panel by inserting it into the tabs from one side to the other until it is completely secured.
Install the control panel on the washer and the top panel in reverse of the removal steps.
Note: Please specify the model number of your washer for the specific replacement parts.
Mar 01, 2010 | Dryers
Washer stops mid cycle
OK.. to the back left of your lid, under the top casing, by the hinge.. you have a hook metal bar that activate the lid switch.. hard to describe, but I'll do my best.. use left hand lift up on down on lid.. use right hand, reach under lid and find metal hook.. ok.. push up on lid and right hand push back on metal hook slightly(not to much).. now try closing lid and see if you heard clicking noises.. also, in the future try not to let the lid drop down, that will bend the hook.. hope you got it.. good luck...mike
Jan 23, 2009 | Washing Machines
Whirlpool washer stops in mid cycle
check the connection at the main control board top right side just remove the top
Nov 29, 2008 | Washing Machines
Hp deskjet 960c
You say it stopped working mid-print... possible paper jam? Ink cartridge not clicked in all the way? (they should all line up evenly across the tops).
In control panel->printers and faxes, right click on Canoni960 and choose properties. In maintenance tab try to do nozzle check and print head alignment. In lower right corner is status monitor, click to see if any useful information in there.
May 17, 2008 | HP DeskJet 960c InkJet Printer
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
22 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
