Question about Panasonic NV-HD680 VCR
Panasonic NV HD630 is showing error f06 when the eject button is pressed. The tape cassette seems to be locked in and does not rise. I have removed the top. The tape is withdrawn back to the cassette. How can I release the cassette ?
  • Panasonic Master
  • 5,391 Answers
You have a K-Deck mechanism. F06 means the mechanism locks after unload. The cause of this is the load motor or the carriage alignment.
If you enter "Panasonic K-Deck" into google you should find service information and a guide to getting the tape out - all free!
Posted on Oct 13, 2010
How do I fix error F06 on my Panasonic NV-FJ620??
F06 means the mechanism is locking up after unloading. The cause of this can either be the carriage that the tape sits in, or the loading motor. It's important to check for damage on the carriage.
Incidentally I think this model uses a "K Deck Mechanism".
If you search the web for Panasonic K Deck you should find a PDF manual free.
In fact I have it on my blog site under service manuals.
http://therealchart.blogspot.co.uk/p/technical-help-tips.html
Sep 09, 2015 | Panasonic Televison & Video
Have an ND-hd630 vcr that has f6 on display
Are you sure it's not a NV rather than ND?
If it is an NV then you have probably got a K-Deck Chassis model and F06 means that the mechanism is locking up after unloading (getting stuck). This is something to do with either the Load Motor or the Carriage aligment.
There is free information on-line about the K-Deck which can be found by Google search.
Jun 17, 2011 | Panasonic Televison & Video
I have a panasonic nv-hd640 i can't eject tape, when i try to eject give me a error f06 and turn off the video thank you
You have a K-Deck model there's lots of information on the net about these so check it out.
Meanwhile F06 means that the mechanism is locking up (getting stuck) after unloading the tape. The cause of which is either something to do with the loading motor or the carriage (where the tape fits) alignment.
Just type "Panasonic K-Deck Mechansim" into Google for the information.
Jan 16, 2011 | Panasonic NV-HD670BDX VHS VCR
Hi F06 appear on screen;cant eject cassette
You have what's called a Panasonic K-Deck machine. That code means the Mechanism locks after unloading the tape. The cause of this could either be the 'carriage' where the tape fits, or the Load Motor. Plenty of free information on line just type "Panasonic K-Deck" into Google.
Jan 07, 2011 | Panasonic NV-SD235AM VCR
Panasonic NV-SD236B VCR Error code "F 06" Whats the problem? Tape will not eject.
You appear to have a model that uses the K-Deck Chassis. If you enter "Panasonic K-Deck Chassis" into google you will find loads of service information on it.
However back to your problem F06 means the mechanism is locking up after unloading. The cause of which could be either the Load Motor or a problem with the Carriage (where the tape goes) and it's alignment.
May 27, 2010 | Panasonic Televison & Video
Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
Apr 24, 2010 | Panasonic NV-DS65 Mini DV Digital...
Panasonic NV HD620 Error F06
You appear to have a model that uses the K Deck Chassis.
F06 in that case stands for: "Mechanism locks after unload". The cause being either the loading motor or the carriage alignment.
May 07, 2009 | Panasonic NV-HD680 VCR
Panasonic VCR has F06 code
You appear to have a K Mech model. F06 is the code for the mechanism locking after unload. The cause being something to do with the loading motor or the way the carriage is aligned.
Jan 29, 2009 | Televison & Video
Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Need help FAST!! Panasonic NV
remove battery for a while .put it again and try .if not works...remove battery agin then put it again by keeping power switch off. eject and remove cassette .take several eject operations. now try again.
Nov 04, 2007 | Panasonic NV-GS50 Mini DV Digital...
Panasonic NV-HD680 VCR Logo
1,287 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
