Question about Sony PlayStation Portable (PSP) Console
Help! I have a psp and I want to play a game on it but I've never done that before. When I go into the game icon (a pic of a controller, to the right of the video icon) the icon that lets you play the game that you have inserted into the back of the psp isn't there! Please, please help! Thanks!
  • Anonymous Jun 11, 2008
    when i go to play a game the game icon isnt there
    Guru:
  • 134 Answers
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Posted on Jun 11, 2008
  • 97 Answers
You have to wait till the game loads (you wont see the circle thing in the lower right corner after its done loading.)
please rate!
Posted on Jun 03, 2008
WHen I turn on my PSP I get a yellow screen/Menu. It has Settings, Camera, Music, Video etc. How do I exit this to play a game?
This is the XMB its the main menu of the system. Games will be located under the Controller Icon. To play games insert a UMD, or if a game is downloaded and saved on the memory card, go through the icons under Controller icon. A disk icon will appear and show a preview screen to the game, press X to start the game.
Jul 24, 2010 | Sony PlayStation Portable (PSP) Console
Tip
Sony PSP Tips and Tricks
<ul> <li>The PSP is the hottest little handheld around right now. The PlayStation Portable Handheld system is very impressive and plays great games, music and movies. Additionally, the system does have a few tricks as well. Here are a couple of things you can try, some are fairly simple. Please note you must be careful with some of these tricks and they will be marked by a <b>*</b> before the "<i>how to</i>" area. Due to the price and the sensitive LCD screen always use caution when trying anything below.</li></ul> <i>While these tips are listed here, please do not attempt them if you are uncertain about any aspect of them. </i><br /> Jam to Tunes Using Your Car Stereo System Speakers <ul> <li> Use the following instructions to play your PSP games and movies with your cars audio system. <br /></li></ul>You will need a <i>FM modulator</i>, a cable with a <i>male stereo 1/8" headphone connector</i> at one end and <i>split left and right RCA connectors</i> at the other. The red wire with the 'in' line fuse goes to your car battery or switch. The ground wire grounds to the frame. Set the car's CD or tape deck to the FM frequency that is on the modulator. The frequency is usually 88.7 or 89.1. Plug the RCA connectors from the cable into the RCA jacks on the modulator. Plug the headphone end of the cable into the PSP. Turn on the PSP with the volume set at half way. <br /> The PSP's sound goes through your car's antenna. No extra wires are needed nor are any other adjustments. Your games, music and movies will now play through your car's stereo speakers. Please note: take care when trying this and make sure you know how to use the modulator and know the right way to hook up the wire to the fuse box and ground wire. If this is not done right, this can damage or even short out the PSP. This one is for parents!<br /> Changing the Save File images <ul> <li>Whenever you save a game, one or two pictures are created on your memory stick: ICON#.PNG - the 144x80 icon displayed when you select your saved file. The #, normally 0, may be higher if a game places multiple saves in one folder. PIC 1. PNG - the 480x272 background that's displayed when you cursor over your save or game disk. Knowing this, you can customize your save icons and backgrounds by simply replacing them with new . PNG files. However, make sure that you keep the new file less than or equal to the original file's resolution, or the PSP will cut off sections to make it fit.</li></ul><br /> <ul> <li> First Connect your PSP to your PC. Then locate the save file you want to change. All saves are located in the <b>PSPSAVEDATA</b> folder, divided into separate sub folders to keep necessary files together. Once you've found the save icon you want to change, add .ori to the end of the file name, in case you ever want to change it back to the original. Resize the image you want as you're save icon to 144x80 and save it as a .PNG named ICON#.PNG - "<i>where <b>#</b> was the number found on the file you renamed</i>". Then move the new picture into your save folder.</li></ul><br /> <br /> <ul> <li>Now, whenever you see your save files on your PSP, its icon will be the picture you changed it to. Use the same method to change PIC 1.PNG files to your own custom pictures, but remember that the resolutions must be at most 480x272. *Please note this is a bit complicated and could result in losing all saves if not done correctly. <i>This tweak is really for those who have knowledge of using these types of files. Please use caution when attempting this or have someone that knows how to work with these files help you</i>. </li></ul> Choosing a Background Color and Keeping it the Same <ul> <li><b> </b><img src="mike_alozie_1.jpg" />The PSP will change colors of the background screen every month automatically. You can pick a color that you like and have it stay that way. Simply go into the settings and select the month that has that color, when it changes, reselect the month. Note: Your date will always be wrong, but if color and style is your concern, this simple tweak does the trick.</li></ul>
on Apr 23, 2011 | Video Game Consoles & Games
Tip
Psp tips on: backround colour, file images, car stereo system.
The PSP is the hottest little handheld around right now. The PlayStation Portable Handheld system is very impressive and plays great games, music and movies. Additionally, the system does have a few tricks as well. Here are a couple of things you can try, some are fairly simple. Please note you must be careful with some of these tricks and they will be marked by a * before the “how to” area. Due to the price and the sensitive LCD screen always use caution when trying anything below.
Jam to Tunes Using Your Car Stereo System Speakers * Use the following instructions to play your PSP games and movies with your cars audio system. You will need a FM modulator, a cable with a male stereo 1/8" headphone connector at one end and split left and right RCA connectors at the other. The red wire with the 'in' line fuse goes to your car battery or switch. The ground wire grounds to the frame. Set the car's CD or tape deck to the FM frequency that is on the modulator. The frequency is usually 88.7 or 89.1. Plug the RCA connectors from the cable into the RCA jacks on the modulator. Plug the headphone end of the cable into the PSP. Turn on the PSP with the volume set at half way.
Changing the Save File images * Whenever you save a game, one or two pictures are created on your memory stick: ICON#.PNG - the 144x80 icon displayed when you select your saved file. The #, normally 0, may be higher if a game places multiple saves in one folder. PIC 1. PNG - the 480x272 background that's displayed when you cursor over your save or game disk. Knowing this, you can customize your save icons and backgrounds by simply replacing them with new . PNG files. However, make sure that you keep the new file less than or equal to the original file's resolution, or the PSP will cut off sections to make it fit.
First Connect your PSP to your PC. Then locate the save file you want to change. All saves are located in the PSPSAVEDATA folder, divided into separate sub folders to keep necessary files together. Once you've found the save icon you want to change, add .ori to the end of the file name, in case you ever want to change it back to the original. Resize the image you want as you're save icon to 144x80 and save it as a .PNG named ICON#.PNG - “where # was the number found on the file you renamed”. Then move the new picture into your save folder.
Now, whenever you see your save files on your PSP, its icon will be the picture you changed it to. Use the same method to change PIC 1.PNG files to your own custom pictures, but remember that the resolutions must be at most 480x272. *Please note this is a bit complicated and could result in losing all saves if not done correctly. This tweak is really for those who have knowledge of using these types of files. Please use caution when attempting this or have someone that knows how to work with these files help you.
Choosing a Background Color and Keeping it the Same The PSP will change colors of the background screen every month automatically. You can pick a color that you like and have it stay that way. Simply go into the settings and select the month that has that color, when it changes, reselect the month. Note: Your date will always be wrong, but if color and style is your concern, this simple tweak does the trick.
on Jan 06, 2010 | Sony PlayStation Portable (PSP) Console
Umm i my psp can't play songs. i select the music icon then it freezes. this happened right after i changed the original theme and the xmb wave. here are my psp specs: psp model 1001 custom firmware...
hardboot your psp and hold r then you should see recovery menu go to plugins and turn cxmb.prx off okay and then delete the theme from your mem stick and then reenable cxmb.prx
Feb 24, 2009 | Sony PlayStation Portable (PSP) Console
Game Icon is Missing!!
http://manuals.playstation.net/document/en/psp/current/game/game.html
This will help. If not, let me know more about it so I can help you.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
PSP
@DBOY1875
Even the most exprienced psp technician won't figure out what's the problem if you just say "MY PSP IS NOT PLAYING GAMES WHAT THE PROBLEM". There are thousands of "not playing games" problems. Just think what if I reply you with "FIX IT TO PLAY GAMES' ?
GIVE MORE DETAILS! HELPS ME TO HELP YOU.
@Guest
You have to scroll down a little bit, the umd icon is just underneath the gamesharing icon actually.
Dec 25, 2007 | Sony PlayStation Portable (PSP) Console
Cant get games to play on my sons psp
This may be a number of problems. The disc might be scratched or damaged. Or there could be dust on the leans.
You say it's a second hand PSP? In that case, you may need to repare it. I'm not quite sure where to go to get repares. Sorry.
Dec 18, 2007 | Sony PlayStation Portable (PSP) Console
Psp ( i cant get games to play )
Have you inserted the game disc UMD into the PSP itself? You have to wait a few seconds after you turn it on before the game icon will be visible in the main menu screen before you can access the game. When it's active and you have the game icon selected press the "X" button to start the game.
How do i usedownload pic from windows XP to psp
connect the usb cable to the psp and select usb connection. From there, open up my computer and find a "removable drive". That drive should be the psp. Copy your photo from wherever it is and go to the photo folder on the root drive. ex: E:\Photo hope this helps.
Oct 02, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
241 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
