Question about BBE Mind Bender Stomp Box
Hello, I have a mind Bender which I bougth brand new 5 months ago. It suddenly starts to drop the volume of the guitar when I activate it. Any advice how to understand if this is hardware problem or not? Thanks Emre
  • 94 Answers
CHECK THE BATTERIES
Posted on Oct 25, 2010
I hav a Silvertone sslb11 bass that needs a new volume pot and don't know wich one to buy. I don't see any part numbers or values printed on the pot. Does anyone know part numbers, brand, or...
I recommend checking music stores in your area for that, it doesn't have to be any specific rating of impedence. Depending on brand, I see guitars with anything from 50 ohms to 250 ohms. This only allows a faster cutoff on volume than others. The most critical action is to have a smooth taper, meaning a straight volume rise or decline versus one that goes down slowly or quickly and suddenly cuts off. Most any guitar volume control from a music store will work just fine. In case I confused you, ohms is the rating of the control, the taper or smoothness is classed as A, B, or C. A is normally for volume controls and B is used mostly for tone controls. Knowing that should give you insight insight to the difference of the controls.
Mar 31, 2013 | Music
I've only had my 714ce for about 5 weeks. I've used it for 4 shows and during my last show I experienced a volume drop. I unplugged the jack, plugged it back in and it was fine for a bit, bu
It's most likely the battery isn't producing enough voltage, though it may have been adequate for your other guitar.
However, you should discuss the issue asap with your dealer and/or Taylor support.
https://www.taylorguitars.com/support
Support
May 16, 2017 | Taylor 714ce Guitar Acoustic
I have a Ibanez V Series V70CE. It play well. But sometimes when I connect it to the amplifier, there seems to be loose connection and no sound is heard. When I move the wire little bit sound come...
Many try to use poor quality guitar cables and have the problem. The sleeve of the guitar cable plug turns on the battery in the guitar. Always loop the guitar cable through your belt or the guitar strap to avoid the cable wisting the plug in the guitar causing noise and WEAR that wears the plug sleeve to the point it no longer will activate the guitar.
Sep 18, 2011 | Ibanez V Series V70CE Dreadnought Cutaway...
Acx1800 no bass very small volume, brand new amp.how do i put my speakers in phase?
If you are sure that the input device (I'm assuming electro-acoustic guitar) is working properly then it sounds like a clear case for return to the vendor! If it is brand new then don't even try to repair it. The phase buttons on the guitar channel are to help reduce feedback by putting the body of the guitar out of phase with the speakers. The speakers should all be in phase with each other though.
Sep 10, 2011 | Behringer ULTRACOUSTIC ACX1800 2x8...
Hello! I've bought a Fender Rumble 75 about 3 months ago and it sounded great really but after some loud playing (About 75% of max volume) it started to buzz at midrange notes, and its gets worse as time...
Try plugging another sound source into the unit. The buzz MAY be pickup of magnetic fields in your guitar pickup that clobber your notes from the strings. Bad guitar cables are another possibility. By putting clean music from say a CD player into the unit you can find where the source is. If the CD player generates the same noises, then likely you have a failure of filter caps in the amp or other component failures. Also make sure your guitar can't "hear" the amp as feedback can do strange things.
Apr 23, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
I have a Kustom HV 100 hybrid tube amp. When I power it up, It will play normal for about 5 seconds and then the volume drops off. The preamp tube is only about 2 months old and this amp only gets played...
After the volume drops off, let the unit sit idle for a minute and then try it again. If the volume has restored for another brief period, suspect the filter caps are weak and voltage drops when you start driving the unit. In any case you need to have it serviced. Unless you can see the heater in a tube going out with vibration this may not be a DIY repair. If you see purple glow in a tube, replace it.
Apr 04, 2011 | Kustom Double Barrel 30-watt 2x12 Hybrid...
Bought new few years ago. i get adead string only on the b string & only first 3 frets-clears up at 4 fret-g string fine -e string fine. sometimes clears up by itself & is fine 4 few months.If prob...
Sounds like your truss rod needs to be adjusted. This should only be done by a professional. Take your guitar to a shop or guitar store that offers a service like this.
If you really want to do this yourself, though, here's a helpful video that will take you step by step through this:
Hope that helps!
Jan 30, 2011 | Epiphone Les Paul Special II Guitar...
After about 30 minutes of playing i get a drop in bass power a drop in volume also a destorted sound occures during that period i tried changing the battery i still get the same problem i have a schecter...
Have you checked that it is not the amp that is the problem? This is a fairly common thing to have the amp heat up and the thermal protection shut it down partly. Since the bass drops, a loose connection or bad guitar cable can cause that. If the signal becomes capacitively coupled only the treble will come through and be very distorted. Try a new cable. For the guitar, open the electronics area and look for loose or broken wire.
Oct 25, 2010 | Music
BBE Mind Bender Stomp Box Logo
116 people viewed this question
Top BBE Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a BBE Music Expert? Answer questions, earn points and help others
