Question about Philips 28PW6506 28" TV
PHILIPS 28PW6515/05 NO PICTURE
Pinkish purple colour with thin white horizontal zigzag strips (from top to bottom). Strips moves only slightly. I have had the painter chip board checked and found faulty and it was replace by me but still same problem can not get a picture just this pinkish purple colour with thin horizontal zigzag strips (from top to bottom). Same as before I replaed the supposed painter chip.
Please help
  • eamondorosso Jun 02, 2008
    Very nice of you to put me in my place but I need help not a lecture now if you have solution I would really appreciate your advice and help if not save the patronising for a newbie
    regards
    eamondorosso
    i will not stoop so low as to retaliate it is not dignified where i come from.....
    Genius:
  • Philips Master
  • 1,689 Answers
What most likely happened is that the person who checked it saw that there was a fault in the operation of the mentioned board. But, what he could not see because of the complexity of the set, there is a problem somewhere else that is causing this failure. There are many interactive circuits where some sections will effect others on different boards. The different boards have a high degree of interaction between them.
These TV sets are extremely complicated. What is one in the factory service, is they test the set by doing a number of test measurements, and then trying out the suspect boards in a group. Then they use the process of elimination to zero in on the faulty board. When they find the defective board they leave the new board in the set, adjust it according to the service information in the service manual, and then return the set to the customer.
Like computers, most of the service is done with board swapping. The authorized service rep will have the instrumentation and service setups to do the proper calibrations to match up the new board.
This is why I never encouraged a customer to service his own TV set. He can end up buying parts and boards that he may not need because he was testing the set by guessing. These boards are not returnable, because after the board was handled and tried, there is no guarantee that a new problem was introduced on the board. Sometimes there can be a problem on another board that damages other boards that are connected to it.
In the end, we found that it does not usually pay to try to service these sets yourself. At home you don't have the facilities to properly test the set for calibration and performance. You also don't have the diagnostics facilities, training, and engineering information to be able to properly work on the set.
Jerry G.
Posted on Jun 01, 2008
  • Jerry Greenberg
    Jerry Greenberg Jun 02, 2008
    The solution is to send the set to the factory service rep to have it properly serviced. If you send the set to a non factory rep, he will end up sending the set for you. If he took it on himself to borrow a spare set of boards, he may not have the setup to properly calibrate the set after the boards are replaced.
    In going by your description, it appears that the video processor is not having proper clock rate locking from the encoded video signal. The decoding and processing of the video signal is not able to sync lock. This is controlled through a PLL (Phase Lock Loop) circuit that is part of the main processing on this board that you replaced. This is why the person who advised you recommended this board. The fault may be coming from the input processor not processing the reference clocking signal on the input board, or it may be from a fault with the master clocking counter that is from the uPC (Micro Processor) that is for the main system sync, or for the main video processing itself.
    To service your set at the level that I am mentioning above, the service man would need a very extensive and costly setup. For a tech to work at this level would be very time consuming, and he would have to have an extensive in depth knowledge of how the set was designed. This level of service would be more at the factory R&D level. None of the service reps would do this level of service. They would simply swap out boards for new ones until the fix the set. Board swapping is the most cost effective way to service this type of TV set.
    I was telling you the reason why these sets are not able to be self serviced at home even by someone who has a solid TV electronics background. He would have to have the factory training, service setup, and facilities. He would have to invest a lot of money and time in to servicing it just to service one TV set!
    At the service rep, your set would be serviced by doing board swapping. After the defective boards are replaced, the tech would follow the instructions in the service manual to do the performance tests on the set. He would then follow the service instructions to do any necessary calibrations to match the new boards.
    Jerry G.
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Fuji a920 problems fotos
It may be that your SDHC card is corrupted, you should either have your camera reformat it or connect it to a desktop/laptop computer and run diagnostics on it.
Jan 07, 2014 | Cameras
How do I fit the leaf springs back into a front beam of a 1970 beetle?
YOU CAN USE MECHANIC WIRE WRAP AROUND LEAFS OR YOU CAN INSTALL THEM LAYER AT A TIME FIRST INSTALL .TWO THIN STRIPS SIDE BY SIDE ON BOTTOM. THEN SECOND INSTALL FOUR THICK STRIPS ONE ON TOP OF THE NEXT.THEN THIRD INSTALL INSTALL TWO MORE THIN STRIPS ON TOP SIDE BY SIDE. NOW ALL LEAF SPRINGS IN PLACE HOPE THIS HELP. WHAT STATE YOU LIVE IN.I LIVE VA.GETTING COLD HERE IN MY HOME TOWN.
Nov 27, 2010 | Volkswagen Beetle Cars & Trucks
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
My toshiba tn61x81 projection tv
have you tried the convergence option in the menu? i believe it is under "picture". this allows for nine different sections of the screen to be adjusted when projection images get out of whack.
Oct 20, 2007 | Toshiba TN61X81 61" Rear Projection...
Durabrand 21" tv picture distorted
To properly diagnose this problem,access to the servicer menu will be important.Also,the service literature for the horizontal and vertical circuits may be needed.Contact a tech who can help you that is familiar with Durabrand.
Sep 25, 2007 | Durabrand DU1901 TV
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Philips 28PW6506 28" TV Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
