Question about Samsung HLT6187SAX 61" DLP HDTV
I have a very similar problem with my Samsung DLP TV. Three different remotes have been tested so I know it is not the remote. The IR sensor stops working intemittantlay. Smasung service team is no help at all. Does anyone know how to fix or change the IR receiver?
  • 8 Answers
SOURCE: Samsung DLP TV won't come on
It is called a DMD bord and you can fix it your self look at my ether post on how to clean and tighten the screws on it this should fix it
Posted on Jan 02, 2008
SOURCE: Numerous white spots on Smasung DLP TV
You will actually get white and black dots , the black ones are tougher to see because of the color in the background , within 2 months youre picture will be fully covered with dots....I went through the Samsung website troubleshooting flow chart , and it led me to a bad Digital Micromiror Device , or DMD board . What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color . Samsung will not tell me the part number of the chip , they will only offer to send a service tech to my house .
Posted on Jul 30, 2008
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Posted on Apr 07, 2009
  • 4090 Answers
SOURCE: Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Posted on Aug 01, 2009
SOURCE: Smasung 50 Green Screen
I had a 50" DLP sampson with the green screen problem plus it has a power off problem; meaning the TV shuts off for about 10 seconds then turns back on when watching Hd TV it got to be a problem when if happend about ever half hour. The analog TV stations are the only green screen. You had to unplug TV to get rid of green for short time.
If you feel the back cover of theTV, the cover is hot to the touch, so hot in places to make you **** your hand back from the heat.
I removed the lower back section ( had to unplug all cables from back cover,Don''t forget the power cable) I used my shop vac placed the hose on blow outlet and blew out all the dust inside the set. (DON"T put hose to close to TV's componits!) Next I removed TV's LOWER back cover, found vent in back for the TV"s fan (over the heat sink), marked the back vent then I went to local Electronics store.
I purchased one 115 volt fan , one cord that pluged into fan and other end into eletricial outlet. Locating center of TV fan on TV's back cover
find best location to mount fan. ( I check fan before mounting by plugging it in to wall outlet to find out air flow direction) I wanted the air flow pulling air out of TV. I mounted my fan on outside of TV's cover left and up from THE TV"s FAN CENTER.
Remount TV's cover with fan. Plug in all your cables, plug in power and fan. turn on TV. After I done above proseager After 8 hours of tv bring on no green screens, no power shut down. The back pannel of TV is cold to the touch except the vent for the projecter lamp.
The Fan I used is a Orion coolong Fan (Knight Eletronics) Part number OA92AP-11-1TB total cost: Fan and cord, nuts, washers and & bolts Under $25.00. Not bad even if TV just last another few months
Posted on Mar 20, 2010
Remote IR board
This board can be located at the front panel of the TV. You have to open the TV, to take it out. The infrared sensor can be located just behind the infrared window, whci can be located at the front panel of the TV. The sensor will look somewhat like this. e23a7382-203e-4e46-a063-a2a3486f559a.jpg
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Samsung HL-T5076S 50 in. TV
Dish network remote control codes
Hi, my name is Cheri Torres and I work on the Social Media Team at DISH. I would be happy to help you get your DISH remote addressed to your Samsung TV. There are many different codes for each of our different models of remotes. The model number of your remote will be located on the back of the remote at the top, usually a two to three digit number. I will list here for you the best codes for each of our different models of remotes and also the instructions for addressing the remote to the TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me directly at Cheri.Torres@Dish.com.
remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 680, 738, 516, 655, 667, 833, 897, 500.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 738, 516, 680, 522, 664, 833, 755.
4.0 and 4.4 IR/UHF remotes - codes 738, 516, 680, 667, 833, 858, 897.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 738, 680, 516, 505, 755, 833.
20.0, 20.1 IR and 21.0 21.1 IR/UHF remotes - codes 680, 738, 601, 833, 516, 794, 858, 684.
Instructions
1. Press and hold down the TV button until all the lights light up on the remote.
2. Enter the 3 digit code for you TV.
3. Press the pound(#) button once.
4. Test the functionality of your TV.
Apr 16, 2012 | Samsung LN40D550 LCD TV
Kdl-32l504
TV Parts Universal TV Stands DLP Chips ShopJimmy They should have the IR board for your Sony TV.
Sep 03, 2017 | Televison & Video
How do I program a dishnetwork remote to my TruTech Model T2000-D TV.
Hello, Cheri Torres with DISH Network Customer Service here. I came across your post recently and wanted to see if I could help. We have a few different codes for each of our different models of remotes. The model number of your remote will be located on the back of the remote at the top, usually a two to three digit number with a decimal point. I will list here for you the best codes for each of our more popular models of remotes and also the instructions for addressing the remote to the TV. I hope this information is useful and if you have any further questions please let me know!
Models of remotes Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 652, 130, 300, 719, 333, 632.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 500, 652, 719, 632, 333.
4.0 and 4.4 IR/UHF remotes - codes 719, 505, 569, 220, 976.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 506, 719, 727, 505, 529, 504.
20.0 IR and 21.0 IR/UHF remotes - codes 505, 531, 584, 521, 506, 531, 584.
Instructions for addressing the remote to the TV.
1. Turn the TV on.
2. Press and hold the TV mode button down until all the mode buttons light up red.
3. Enter the three digit code for your TV.
4. Press the pound(#) button once.
5. Test the functionality of the TV with the DISH remote.
Oct 19, 2011 | TruTech T2000D TV
I need the Dish Network code for the Remote for Broksonic CTGV-5463GVC 19" TV. None of the codes in their book work.
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. Each of our different models of remotes have a few different codes that could work. I will list here for you the best codes for the more popular models of remotes that we have and the instructions for addressing the remote to the TV. I hope this information helps and if you have any further questions please let me know!
Remote Model #'s Codes for TV
3.0, 3.1, 3.2, 3.4 IR remotes - codes 720, 748, 752, 661.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 720, 748, 752, 656.
4.0 and 4.4 IR/UHF remotes - codes 720, 748, 752, 721, 656.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 720, 748, 752, 533, 656.
20.0 IR and 21.0 IR/UHF remotes - codes 834, 899, 750, 748, 533, 622, 754.
  1. Turn the Television On.
  2. Press and hold the TV mode button until all the mode lights light up red.
  3. Enter the three-digit code using the buttons on the number pad.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 27, 2011 | Broksonic CTVG-5463GVC 19" TV
I need code for remote to programme dish network on one remote
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. Each of our different models of remotes have a few different codes that it could work with. I will list here for you the best codes for the more popular models of remotes that we have as well as the instructions for addressing the remote to your VIZIO TV. I hope you find this information useful and if you have any further questions let me know. :)
Remote model #'s Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 505, 165, 671, 627, 520, 758, 766.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 627, 505, 506, 006, 457, 520.
4.0 and 4.4 IR/UHF remotes - codes 505, 627, 766, 864, 593.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 627, 505, 678, 458, 825, 758, 520, 766.
20.0 IR and 21.0 IR/UHF remotes - codes 505, 598, 627, 523, 520, 720.
  2. Press and hold the TV mode button until all the other mode buttons light up red.
Sep 08, 2011 | Vizio 42 in. LCD TV
New Vizio 19" TV I need to get the code into the
Hi there, Cheri Torres with DISH Network Customer Service here. I came across your post recently and wanted to see if I could help. We have a few different codes for each of our different models of remotes. The model # of your remote should be located on the back of the remote at the top, usually a two to three digit number with a decimal point. I will list here for you the best codes for our more popular models of remote and the instructions for addressing the remote to your TV. I hope you find this information useful and if you have any further questions please let me know!
Remote Model # Remote codes
  2. Press and hold the TV Mode button until all the mode lights light up red.
Sep 04, 2011 | DISH Network EZ Remote Remote Control
Have the dishnet remote and want to put new codes in for a un46c8000 samsung tv
Hello, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. You will be able to find the model number of your remote on the back of the remote at the top usually a two to three digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes and also the instructions for addressing the remote to your Samsung TV. For the 3.0, 3.2, 3.4, 5.0, 5.2, 5.3 and 20.0 IR remotes the best codes are 680, 738, 833, 738 and 516. For the 4.0, 4.4, 6.0, 6.2, 6.3, 6.4 and 21.0 IR/UHF remotes the codes are 680, 738, 516 and 833. I hope you find these instructions and codes useful and if you have any further questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com. :)
  2. Press and Hold the TV Mode button until all the other mode lights light up.
Feb 14, 2011 | DISH Network IR Remote Control
Intermitten remote sensor issue
Evidently 2 good remotes point at the problem being the remote sensor on the TV itself. I have about 4 remotes I can adjust volume w/ including the remote that came w/ my samsung. The TV exhibits the same behavior w/ all of them.
Per the samsung site, the "test" for this (remote vs sensor) is to us a digital camera, (including the kind that's on most cell phones) to "see" if the remote lights up. Just point it at the camera/phone, and press any button. You should see a bright flashing light on the camera/phone's LCD screen. If not, REJOICE! All you need to replace is the remote or batteries in it. If you do see the light, good luck if you're not in warranty. I've been unable to find any procedures for replacing this kind of item.
Nov 13, 2007 | Samsung DLP HL-P5663W 56" TV
Remote Sensor
Start a DVD playing, cover the IR sensor on the DVD player with something opaque. Try changing the volume, the player should keep playing. Your TV, surround sound, and DVD player have conflicting IR codes. The DVD player probably does not use a discreet IC to filter the IR sensor, and the processor in the DVD player is having to look at all the IR codes picked up by the IR sensor. Go to Walmart or KMart and buy a new DVD player for $29.00 or stop changing the volume while watching DVDs :) Sorry, there's no real solution that I know of. Paul.
Jan 01, 2007 | Norcent Technologies DP313 DVD Player
Samsung HLT6187SAX 61" DLP HDTV Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
