Question about Brother MFC 240C All-In-One InkJet Printer
Rfilling How do you refill an ink cartridge for the MFC-240C? Just where do you put the ink in?
  • bud_clara Dec 19, 2008
    i have a mfc 240 iv installed ink but HOW do ya load a LC-51 i need pics or somthing i cant fig a way can ya HELP
  • roozee4 Jan 12, 2009
    none of the pics of cartriges in my kit look like mine. not even the one listed in the solution to the previous question. i just need to know where to put the ink.
If you bought a refill kit you will find a screw type rod. You have to make a hole and Fill it trough there. Then cover it with the little caps that come with the set. The best way to open the hole is to heat a large paper clip and make the hole with it.
Posted on Jun 03, 2008
How i refill ink in the printer mfc240c?the printer is from brother
If you refill the cartridge you broken the print head (clogged),and need to change.Do not refill the cartridge!!!!I'm a technician brother :)
Mar 09, 2011 | Brother MFC 240C All-In-One InkJet Printer
I put a new ink cartrige in and the printer says no cartrige in any solution
your ink refill is the problemm,you need to clean de sensor of the cartridge
Feb 25, 2011 | Brother MFC 240C All-In-One InkJet Printer
Model mfc-240 makes all the sounds as if printing but the paper comes out blank! nothing.
it shows that the ink has dried or finished, try to replace or refill the ink cartridge
do rate the solution if helped
Nov 26, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-240c doesn't recognize ink cartridges that I put in
It may be a memory issue.
Unplug the machine from the power.
Remove all the ink cartridges
Replug the machine and reinstall the ink cartridges
Jan 19, 2010 | Brother Multi-Function Center MFC-240C...
Brother Mfc 240c will not print using black ink... cleaned and reinstalled ink cartridge that is full, but has been refilled. Any chance this is an easy fix issue?
we can refill 100 times but it woks.probly refiling methood is mistake. one time pul out all ink and gas of cartage by sering.and reffil again.
Oct 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Refilling ink Cartridges
There is a service hole on the cartridge that u need to unplug with a small drill bit or some type of hole puntch. Then u need to cover the hole with the stickers it came with..
Apr 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Refilling ink cartridges
NVER EVER USE REFILLS ON BROTHER MACHINES, THE PRINT HEAD WILL GO BAD, I AM A SERVICE CENTER FOR BROTHER
Dec 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Magenta Color Doesn't Print
refill ink cart can be problem here, print head may be blocked , try cleaning the head in warm water
Feb 02, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
109 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
