Question about Amana ARSE665BS Side by Side Refrigerator
My name is Thomas, My refrigerator is not getting cold and there is build up of ice in the back of the freezer. I would like to fix the problem but cannot locate the manual to further troubleshoot. I am aware that the problem could be the - Defrost Timer, Defrost Heater, and or Defrost Thermostat, Just need manual to located, troubleshoot and replace part or parts. What do you suggest? In desperate need of help.
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
  • 116 Answers
SOURCE: I have an Amana bottom
Typically with this model it is either the timer or the defrost thermostat.
This is behind the back wall of the freezer. It is attached in series with the element. It is designed to open when the heater gets hot enough. The part is about the size of a stack of 6 quarters and typically has a blue end coating on one end. The other end is silver in colour and should be clipped on the black coloured heating element. It will have 2 wires coming out of the blue end.
If this part is defective then it will have to be replaced. by cutting a splicing a new one in. Be sure to unplug the fridge before replacing it.
There are 3 main components that can give issues; the timer, the thermostat and the heater. All 3 should be checked to confirm the fault. NOTE the timer contacts can be burned out as they arc under normal operation.
If you have a multimeter then you can check if the heater circuit has 0 or close to 0 resistance when there is frost on the back wall of the freezer. if it is then the timer is bad.
Posted on Jul 28, 2008
  • 1462 Answers
SOURCE: Air Flow to Refrigerator keeps getting blocked by ice buildup
yes it is but check any plug and socket wiring as well
Posted on Aug 31, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
Our Kenmore frig is not cooling at all! The freezer is doing great however. What could be wrong with it and can we fix it ourselves to save money?
For one reason or another the cold air is not getting from the freezer compartment to the refrigerator side.
Possibilities Are There is ice build up in the vent. The vent is stuck closed or set at closed setting(freezer setting to cold) Defrost thermostat in freezer area not defrosting ice to allow air flow. This you can tell once you remove the back panel in the freezer you will see the inside full of ice.
May 26, 2011 | Kenmore Refrigerators
My Jenn Air Model No# JSD2789DES Refrigerator does not stal cold and freezer is not freezing anything...I noticed in the back of freezer the wall was covered in ice. It was working fine the other day...
Ice building up in the freezer is not good, it means that your defrost heater is not working.The purpose of the defrost heater, as the name implies, is to prevent ice from building up on the evaporator that is inside the freezer compartment. The heater and/or thermostat failure is responsible for the ice building up in the freezer. Replacing both of is recommended, but if the heater shows continuity with an ohmmeter, just replace the thermostat; if in doubt, replace both of them and your refrigerator should be back to normal. Do not forget to clean the refrigerator condenser fins.
Dec 12, 2010 | Jenn-Air Refrigerators
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge not pumping any cold
All your cold air for the fridges comes from your freezer compartment.If you are haveing ice build up in the freezer comparment there may be an issue with your defrost circuit.
While the unit is in a cooling mode open the freezer door and listen to for the fan running in the freezer this is the evaporator fan that circulates the cold air to your fridge compartment if it is not running replace it.
If it does run try and check your defrost circuit and make sure the unit goes into the defrosat cycle
May 19, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Frig warm, Freezer Cold
I have experienced this with other refrigerator freezers. The most likely cause is that the warming element in your automatic defrost system is no longer working. Ice is building up on the cooling coils and this prevents the refrigerator from getting cold. I have always called an appliance repairman to fix (~$150). If you're handy you can try yourself, but you still have to buy the part at retail. Good Luck
May 03, 2009 | Refrigerators
IceBoxnot getting cold
sounds like a similar problem I have, but with a top loaded freezer/refrigerator. I took the back panel of the freezer out (carefully so as not to break anything). I discovered ice covering everything; coil, defrost heater, and perhaps a defrost timer (I didn't see one). I suspect (according to what I've been able to find on the internet without having to pay for a response) that the defrost heating element and/or defrost timer are defective. I only use this 4 yr old refrigerator seasonally, so I don't mind having to manually defrost the freezer. I will try to get parts in the states when I return in the fall. This doesn't tell you how to repair the problem in entirety; but it may give you a hint and possible temporary solution. Oh, I used a hair dryer to melt all the ice covering the above noted freezer parts. My refrigerator is working just fine; however, I'm sure that it'll build up with ice once again. I'm leaving in 6 weeks, so I don't care so long as I know that I can remedy the problem for now. The article I read recommended using a volt meter tester; that I'm not familiar, it may very well allow me to determine which part is defective. The heater coil is about $25, I didn't check on the timer. Try this site: http://www.applianceaid.com/defrost_cycle.html . Good luck. Tom
Jul 26, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerator not cold.
if the freezer section is still working ok then check for ice build up inside freezer on the back wall, its possible that the unit is not defrosting and ice is building up on the cooling coils, the most common culprit is the def thermostat. easiest way for you to get it going again fast is to manually def the coil.
remove the 2 screws about half way down the back freezer wall. then using a blow dryer def the ice from the coil.
since this refrig has an electronic def control i would recomend calling a reputable service company to check it further for you..
Dec 19, 2007 | Maytag MSD2456G Side by Side Refrigerator
Amana ARSE665BS Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
