Question about Fisher and Paykel (IWL12)
My f & p fridge randomly will be beeping like i have left the door open but it is shut, when i open the door the interior light is off and sometimes the electronic lights in the back are flickering, when i turn fridge off then back on it goes fine again for a random period of time. any ideas??
  • 132 Answers
Door not shuting properly and not makeing a good connection with button.
Posted on Oct 13, 2010
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
Beeping & not cooling
Hi Hope, usually when the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut OFF. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm is reset.
The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping.
If the alarm keeps on going off after the doors have been closed and unit has been reset, I recommend contacting a professional technician so they can diagnose and repair your refrigerator.
Sep 10, 2012 | Frigidaire FRS3R5EMB Side by Side...
GE GSS25WGMC door open alarm beeps and both doors are OK and seal properly
check to make sure in fridge and freezer there are switches when the door make contact with it it shuts off the lights-check by hand by holding the swiches down and see if the interior lights go off, if not then you have a bad switch..if they go off then the control where the door alarm is located needs to be replaced
Oct 01, 2011 | Refrigerators
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Keeps making beping sounds
Not shuting off..it is off if the dispaly and lights are not illuminated
Dec 23, 2008 | KitchenAid KSRS25IL Side by Side...
E249T Fisher and Paykel Beeps when door opened
Disconnect the Fridge for 5 mins. After that, should be ok.
Nov 19, 2008 | Refrigerators
Kitchenaid KSCS25INSS
im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
3 beeps
We had the same problem. Our fridge was beeping and the lights would not come on. To stop the beeping and turn the lights back on we had to press the OVER TEMPERATURE RESET button. As soon as we did this, the lights came back on and beeping stopped. Hope this helps.
Sep 29, 2007 | KitchenAid Superba Architect KSCS25INSS...
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
