Question about HP Pavilion F1703 17" LCD Monitor
Computer monitor brightness display will not go away. adjustment buttons do not work when depressed. on, off button does not work
  • grassod Sep 03, 2008
    brightness and OSD menue displays will not go away. adjustment buttons do not work when depressed. on, off button does not work
This is already a replacement monitor that has worked alright for about a year now. Do you think they sent me another bad one?
Posted on Sep 24, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
I have the exact same issue with the f1703 monitor - the OSD will not turn off. Apparently, this model monitor was defective, and was recalled by HP. However, they failed to give notice, so I would recommend following up with them to attempt to get it replaced. Good luck!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 23, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Blurry flat screen monitor
yes you can use those button to adjust the brightness. just press one of the button then it will appear the set up and adjustment.
Oct 07, 2012 | Mag Innovision Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
My LG Flatron Wide Monitor is set for 100% bright, which washes out the image. How can I adjust the brightness? L204WT
Does this monitor have an OSD (On Screen Display),
and a button to activate the OSD?
Does the OSD have the capability to adjust the brightness?
Oct 29, 2009 | Computers & Internet
My screen is too bright and hurts my eyes. How do I dim it a little?
he on the monitor you can find small buttons ,, you can just go select menu button from there select brightness section,, all this appear on display screen,, once click on button.. where u can adjust
Oct 05, 2009 | Acer V193w LCD Monitor
Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Sep 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
How do I adjust brightness on Dell E152FP monitor
there's a buttong located on your monitor. just look for it then set up brightness to watever display u want.
Jul 03, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Desktop screen display goes blue
can u boot into the system?if not it can be solved if yes then there is a problem with ur monitor
if u cannot boot intoo the system load default or system restor tht u do ,......savio k frm mumbai savio_k20@yahoo.com let me know if u solved it
cheers
Jul 05, 2008 | HP D2835 17 in. CRT Monitor
Hp pavilian f1703 monitor
Press the menu button again (or when done adjusting) and it will go away.
May 09, 2008 | CTX S762A 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
