Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker doesn't work
Hi, i payed for technical support on Saturday and the tech told me to manually add water to the ice machine and if it doesen't work replace it to fix the problem, How do i know its not the water not getting there or something else? The ice machine made the ice, It just didn't drop the cubes. Do you have any Ideas, or is the first tech right?
  • 2 more comments
  • ctbk Jun 02, 2008
    The only holes I can see are in the back of the ice machine in I will have to remove it to get to any wires, just so were on the same page, The Refrigerator is a side by side Whirlpool gold conquest Model # GS6SHAXMS00, About three years old
  • ctbk Jun 03, 2008
    Found the T and H . Crossed them over with the Infer Red Flap closed and Nothing happened.
  • ctbk Jun 03, 2008
    I'll take that back The machine got hot, like it might do before it turns out the cubes
  • ctbk Jun 04, 2008
    Master tech Is Great, Use him, I payed for help and the Fixya program isn't the best deal right now, I need to talk or email some one soon. i leave town for a week in two days and need this fixed. and I don't want to play games. I payed, I want to talk to some one, and get the problem fixed with out the. I emailed you and you emailed me back a day later. The twenty dollars I payed you should give me a Tech to email on the spot and get the problem fixed or a part replaced.
    Would someone help?
  • 770 Answers
I would test cycle the ice maker first now that the water is in it and frozen you will need to remove the plactic white cover off the head of the unit you will see some holes in the face of it make a small jumper wire and jumper across the T and H (push in the wire into the holes) this will need to be left in for about 10 secs to start the cycle then pull it out watch and see what happen in the cycle let me know PS: some units required the door to be closed for the IM to work so hold the switch in or if your model havs the ice bin on the door ..close the flapper on the red optics
Posted on Jun 01, 2008
  • Gary Davd
    Gary Davd Jun 02, 2008
    Yes we are on the same page your unit has a icemaker that is mounter sideways and the bucket ins on the door right? so read my comments on my last post you may need to remove the 3 1/4" screws from the bottom of the im to twist it towards you and find the jumper spots with the cover removed
  • Gary Davd
    Gary Davd Jun 03, 2008
    you will need to unplug the IM and check the power at the Black and white wires on the power Molex for 120vac
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
My ice maker doesn't work. Where do I start? Model number 561
HI.FIRST MAKE SURE U HAVE TURNED IT ON.SWITCH OR LEAVER.2- WATER ON 3-WATER IN ICE TRAY.4 IF EMPTY PUT SOME ON MANUALY.AND TRY.IF IT WORKS ONCE AND STOPS THEN U HAVE A WATER SUPPLY PROBLEM.CHECK PIPE;WATER VALVE.IF ALL OK THENNNN...ICE MACHINE?HOPE THIS HELPS.ALI
Jun 30, 2012 | Sub-Zero Refrigerators
Ice machine stopped working
Add some water manually to it. If it kicks out a batch after a while but no more then I would replace the water supply valve. If ice is already in the mold then your ice maker is faulty.
Service manuals
Mar 05, 2012 | Refrigerators
My ice maker just have freeze one side
Check the Freon again. Sounds like it is leaking out.
Dec 23, 2011 | Hoshizaki KM-630M Crescent Cuber Ice Maker
No matter how much water is in the reservoir, the Add Water error message won't allow unit to work.
Hi take out the water tank and place a magnet where the float would sit. If the machine works, then the float is faulty or upside down. If it doesn't work then the sensor behind the magnet is faulty. Replace it. dazza
Oct 11, 2011 | Keurig B60 Coffee Maker
My ice cubes are not solid and very thin I have had a lot of repairs for m;y ice makers. One time a tech told me the water leading to ice maker is no good. Is there anything we can do to solve thin ice...
HI.CHECK FOR WATER SUPPLY VALVE WATER PRESSURE COMMING INTO THE UNIT,AND REFRIG SELENOID VALVE,IF THE PRESSURE IS OK ,REPLACED THE ICE MAKER,,ALSO CHECK FILTER AND WATER TUBE FOR WATER LEAKS..
Jul 05, 2011 | Sub-Zero 650 / O Bottom Freezer...
We have an Amana AFI2538AEW we have had two techs. out already and we have replaced the fill valve. But still we have no ice. What happened is it started leaking water out of the fill cup in the ice...
There should be a float connected to this valve that tells the valve when to open and when to close it kinda works like the float valve in your toilet (check this float),as far as the water leaking out of the cup in the ice maker the float probably bad, Hope this works for u
Apr 03, 2011 | Amana Refrigerators
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
ICE MAKER
Your ice maker works off a different side than the water dispenser. Most times the water control valve is the problem yet it has 2 sides one for water and the other for ice. You can check the ice maker by filling with tap water. Let it freeze and if it dumps the ice and tries to refill I would say the water control valve part number 4389177 will need to be replaced. Sea Breeze
Aug 24, 2009 | Whirlpool GD5SHAX Side by Side...
Ice maker not producing any ice
BG...I'd buy into what the tech is saying. There are a number of ways water gets in but usually, it is a solenoid valve which lets water into the tray. The valve is controlled by a float switch. Usually, these items are replaced as a unit. When you touch them, everything cracks. If no power, then none of the functions will work...no water flow, no auger action.
Feb 01, 2008 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
227 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
