Question about Zanussi ZM24ST Microwave Oven
Have melted the supporting knob, the knob that is attached to the drive shaft, under the glass plate. Does that thing come as a spare part? Best Regards Mats
Glass plate won't turn
It could be the drive block is cracked; remove and look for a split in the shaft.
Jan 03, 2016 | Microwave Ovens
Can I put the lid of my slow cooker in the oven? I'm cooking conventionally using just the crock. Val
I wouldn't recommend it as the lid has a plastic handle which will melt. The covers
themselves are made of pyrex glass generally and would stand the heat, It is just
a concern as to what material is attached to them as far as knobs and trim ring.
Hope this helps.
Jun 05, 2011 | Microwave Ovens
The piece holding the glass turntable does not turn appears to be burned on the insert peg and smells of burnt machine oil
Hi
Sounds like its either the shaft is gummed up with spillovers or the motor has seized because of either spillovers or lack of lubrication ( they usually go for years tho)
If mechanically minded you will need to remove the glass cooking plate, REMOVE THE POWER CORD, turn the whole thing upside down to see if you can access the motor by removing a metal plate etc - if so see if the shaft can be turned by gripping carefully (so not to damage) with pliers or similar. If it moves apply a drop of oil to the area where the shaft enters the motor - chances are the bearing area there is dry of lubrication. Clean off any food debris also and leave wiring alone.
If it now moves freely, reassemble, replace bottom cover plate and turn right side up, plug in and try.
Otherwise if not mechanically minded or still no go you will need to have it serviced
Jun 09, 2010 | Microwave Ovens
The plate is not turning
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need.
If the model number is correct, the part number for a replacement motor is WB26X10038. You may also check the turntable shaft to make sure it is not stripped and slipping on the motor shaft. The part number for the turntable shaft is WB06X10138.
If you have any questions, please post back and let me know. I hope this helps you.
May 12, 2010 | GE JVM1660 Microwave Oven
Plastic peice that fits under plate inside micowave that makes it rotate
If the model number you have this question listed under is correct, there are two possible parts based on your question. There is the carousel ring, that turns the glass tray, and there is the small plastic coupler that the center of the glass tray is supported by. The part numbers are as follows:
Carousel ring - WB06X10513
Coupler - WB06X10564
You can view and excellent exploded view diagram of this microwave at pcappliancerepair.com. The parts I mention are listed under Diagram 1151005 as items 84 and 101 respectively.
To replace the coupler, you simply remove the glass tray and gently pry straight up. The coupler will pull off of the turn table motor shaft. Insert the new coupler and press on to the shaft.
If this is not the correct model number, please post back with your correct information so that I may be able to provide you with better assistance. I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
PLMVZ169HCA Turntable slips on the glass plate
hmmm? me's thinking about this one!!!!
the glass plate has drive dogs on the bottom of it, that fit into drive dogs on the turn table, if its not meshed up right it just spins freely and normaly throw's the glass plat off??? are the bearing that are under the glass plate turning freely? thats the big ring that the plate rides on near the out side edge of the plate, and can be taken out for cleaning??? it looks like a hoop with 3 or 4 rollers in it??? if you forgot to put this bit back in the right way up after cleaning it thats the problem???
Oct 23, 2009 | Frigidaire PLMV169DC Microwave Oven
The spinning plate in my Microwave broke.
Hi there! Universal Glass plates are available from a good local appliance spares shop. Please note that size of the plate, the coupler (The centre connection point to the plate) and the ring size (on which the plate rests) are all important to the correct function of the plate. Take these along for correct matching if you can or they may even keep your particular Model and Brand. Best Wishes and Good Luck, JUS004
Aug 30, 2009 | GE Microwave Ovens
My above the range Maytag Microwave oven plate does not rotate. Bought a new rotator wheel as the old one was broken, and the central spindle will rotate, but not with the plate on it. What can I do?
The spindle (called a turntable shaft) sits atop a small motor shaft from the turntable motor. You either have a weak turntable motor, stripped shaft (which allows the motor shaft to free spin when it has any weight on it), or both.
The turntable motor is located under the bottom panel of the microwave oven. You do not have to uninstall the oven for this repair.
First, unplug the unit, remove the glass carousel tray, and pull straight up on the turntable shaft to remove it. Next, locate and remove the series of screws along the bottom panel underneath the oven. The bottom panel will open exposing the drive motor. The motor comes out by disconnecting the connector plug and a couple of mounting screws.
If the model number you have this listed under is correct, you can view these parts at searspartsdirect.com. Locate items 11 (turntable motor) and 14 (shaft) under the "Cavity" heading. Other sites you may try are pcappliancerepair.com, appliancepartspros.com or repairclinic.com to see if you can find these parts any cheaper.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 05, 2009 | Maytag MMV4205 Microwave Oven
Lost Turntable Knob
That would be the turntable coupler.
Get help locating a servicer or parts at 1-800-695-0098.
Aug 31, 2008 | Emerson MW8168B Microwave Oven
Zanussi ZM24ST Microwave Oven Logo
Top Zanussi Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
acmservice
Are you a Zanussi Microwave Oven Expert? Answer questions, earn points and help others
