Question about Toys
Where do I find an english instruction manual for a T-Series LCD Pro 2 T23 Thunderbird remote control helicopter?
SOURCE: Just bought a 9053 helicopter.
did you put all 8 of the batteries in it? it takes 8 AA batteries.
Posted on Jan 13, 2011
SOURCE: Looking for an english instruction
http://www.mjxtoys.com/
I received my heli today, and downloaded the english manual from there.
manual
Exploded Diagram
Posted on Mar 23, 2011
SOURCE: My new u-control helicopter is experencing spinning
how much is it spinning after and if not to much adjust the st. trim on the controller.
Posted on Mar 05, 2010
SOURCE: ive a s006 alloy shark remote controlled helicopter
have you tried using the trim buttons?,after take off when its around 2ft in the air if the tail spins to the right tap the left trim button a few times and if its spinning left tap the right button a few times and this should stop it spinning it works ok on my one
Posted on May 07, 2010
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Posted on Dec 26, 2010
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
SJ-250 Series Gyro 3.5CH Helicopter instruction manual
I can't find one online. There is a pretty good instructional review here, plus this person presumably has a manual. Having said that, one site says the instructions are in really bad, Chinese English.
It only flies for 6.5 to 7 minutes and as it uses infra-red remote control is really only suitable for indoor use. Be careful of flat screen televisions, as I read of one guy crashing this crash-proof helicopter into a 55" flat screen and damaging it!
SJ Series SJ250
Apr 19, 2017 | Toys
Just purhased two Tier-One Gallant helicopters. They say they are 3 channel. I see no channel selectors on remote or helicopter. I want to fly two of them but don't think I'll be able to unless I have them...
You cannot easily change the frequency these helicopters operate on, they are not designed for multi channel use. To change their operating frequency you would need to find and replace the small crystal inside the helicopter and also inside the remote control.
The 3 channel you are referring to is the number of functions (channels) you can control on the helicopter, not it's frequency channel.
Dec 31, 2013 | Air Hogs Havoc Heli Helicopters
Hello, just been given a syma s006 for xmas, charged it up for max 110 mins as indicated in manual, though LED never came on to indicate full charge. LEDs do come on flashing when switched on at model. New...
try this,switch the helicopter on,then make sure the left controller stick is fully down then turn the controller on,move left stick fully on then fully off should be ready to fly,have fun
Dec 27, 2010 | xheli 3 Ch Syma S006 Alloy Shark RC Remote...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
I have a brand new Syma model S031G model toy helicopter. I have no instruction manual. It has been charged and the lights work. My remote has new batteries. But it will not make the blades rotate. Can you...
Looks like a board circuit problem. If its new, you have to return it and replace it with another one, try it before going home.
Try this, open the board, there are two trimming resistor adjustment, one for the rear motor and the other one controls the main motor, try to adjust it while your switching the remote controller to lift.
If that does not work. The little servo on the board are busted and you need to return the product!
Thanks for using Fixya!
Dec 15, 2010 | xheli Syma S031 Outdoor RC Helicopter
Multi-functional intelligent helicopter KZ-SERIES
I bought a KZ-SERIES 3.5 Channel Multi-Functional Intelligent Helicopter last year.When I tried playing it at first, it worked but on the second time it didn't..I think the problem is that the helicopter cannot receive any signal from the remote control eventhough both the unit and the remote have power.Thank you very much in advance.
Oct 23, 2010 | Toys
Shuttle 9094 r/c helicopter spinning on take-off
usually trim adjustments are on the controller... not on the vehicle itself.
a potentiometer os a fancy word for dial adjustment. It wont be a metal screw, but probably a metal square with a plastic looking slot that can be turned. usually white or blue plastic
Dec 22, 2008 | Shuttle 9094 Emax Remote Control...
Codes for universal remote control
i have the list of codes for the 40085 HTFB, but no instructions. (I assume this is because it's LIDL - their store security is a joke). Which code do you want? And do you want to swap for instructions on how to set up for a specific TV?
Jan 10, 2008 | Universal Remote Control URC-6131N Remote...
Toys Logo
586 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
