Question about Technics Audio Players & Recorders
I have a Technics SA-GX190. When I plug the ac cord into the wall and turn the reciever on the fuse always pops. What could cause this to happen?
    Genius:
  • Technics Master
  • 1,550 Answers
My dear friend the cause are the audio amplifiers IC's are damaged.
Posted on Jun 01, 2008
I have a technics SA 400 reciever. All the lights work when turned on, but no sound is coming out.
If your technics SA 400 reciever turns on all the light but does not seem to produce any sound. Then you need to understand that there seem to be a problem with the unit.
The problem mainly if from the output of the receiver. Check to see if the cables are properly hooked up to the receiver. Then also check if the volume is not on the lowest. Then you try to test other cords on the device to know if the problem is not from the cords.
If it is confirmed that the problem is not from the cord, then it means the jack/port is faulty and need to be replaced.
Have the jack replaced or the ports on the receiver and it will work perfectly fine.
Hope this was helpful
Goodluck,
Elect_Comp
Jul 18, 2011 | Technics Audio Players & Recorders
I want to buy a Technics SA-DX940 reciever
ebay cheap as chips just keep your eye out for them there always about look for the sa-ax730 aswell more or less the same
Jul 23, 2010 | Technics SA-DX940
Balance Knob Technics SA-GX190
Sounds like a dirty pot. With the receiver off turn or slide it back from one side to the other. Test it, if its a little better you can clean it with a little (a drop or two) of wd40, You will probably need to remove the cover to get to it.
Nov 16, 2009 | Audio Players & Recorders
My Wii console won't turn on.
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
- THEN, buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
F70 on my reciever
Most likley it is in need of repair. I suspect the output IC. Check for bad solder connections on the IC and voltage regulators.
Remove the speakers and see if it still happens (it probably will).
Feb 11, 2009 | Technics SA-DX940
Need a new power cord....misplaced mine...
i did the same thing. replacement at radio shack.
Jan 17, 2009 | Technics SA-EX140 Receiver
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
Not working
Operationg instructions says it is "F 70". When it appears it says to turn the unit off, disconnect the aC power supply cord, then reconnect and turn theunit on. Consult your dealer if "F-70" remains on the display.
Mar 30, 2008 | Technics SA-DX1050 Receiver
Missing ac plug for receiver
If the AC plug is the standard "D" shape with the indents for polarization of the cord on both units, yes ou can.
Dan
Mar 25, 2008 | Technics SA-EX510
563 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
