Question about Maytag Washing Machines
My washing machine is leaking from the base of the tub where it meets the black thing that spins the tub. how do i fix it?
  • samsiciliano Jun 01, 2008
    it's leaking from the bottom of the tub, right at the main tub seal above the transmission.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..that's your drive/transmission..are you certain it's leaking from there? could be just where it's showing up.
    Genius:
  • 3,587 Answers
Then you'll need to replace that seal..this something you enjoy doing?
Posted on Jun 01, 2008
Maytag washer model MAV6200AWW
pop off the front panel and look at the inside of it,if you see black dots on the bottom half and on the other walls like half way up from the bottom you have bad tub seals,the seal is made of metal and rubber,when it leaks and in spin it will shot out water and it will be black from the rubber,also you can fill it as high as it will go,then turn the timer to spin and watch where the tranny.and tub meet,if it sounds like marbles spinning and grinding and water leaks out it's the seals.if so time for new washer
Jun 23, 2013 | Washing Machines
Kenmore 43042 front loader, black boot (?) twisted and loose
the black gasget on the inside of the door is suppose to be loose and flexible for sealing purposes.
when your washer went thru it's spin cycle is it possible the throw pillow got cought between gasget and wetal tub?
also is this the only time you noticed this ?
Oct 01, 2009 | Kenmore 46462 Front Load Washer
Leaking washer
This is going to be the tub seal. Take the front off and check to see if the water is leaking right where the tub and the transmission meet and if so the seal is leaking. This also makes the washer noisy. This page should help http://appliance-repair-it.com/Maytag-tub-seal.html
Sep 15, 2009 | Maytag LAT3600A Top Load Washer
Leak during rinse and final spin
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 20, 2009 | Washing Machines
Siemens Siwamat 2105 washing machine leaking
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 10, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Water leaking from bottom of front lode washing machine
During fill only
All the time
During fill only
All the time
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
My bosh is leaking
During fill only
All the time
During fill only
All the time
Oct 31, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Ge washing machine is leaking from the Bottom
During fill only
All the time
During fill only
All the time
Aug 12, 2008 | GE Profile Performance WPSF4170WAA
Leaking washing machine
During fill only
All the time
During fill only
All the time
Jul 10, 2008 | Ariston Technologies AWD121WH
My washing machine is not working properly!
During fill only
All the time
During fill only
All the time
Jun 02, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
