Question about Samsung Televison & Video
I have a 60' inch projector screen. It still works but the panel is cracked on the side from top to bottom. I was wondering how much would that be to replace the panel?
  • 1,476 Answers
Sonnarasam,
With no model number I can't look it up for you but if you go to http://www.encompass.com and search on the model you should get a list of units and find the part in that list. If it isn't listed they will research it for you for free. Just click on research and ask the question.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 13, 2010
There is a line down right side of projected image, from top to bottom, different computers. Thanks Loren
I have a 2 inch white line down the middle of the screen from my Infocus DPL projector.
Can you help?
Paul.
Nov 29, 2010 | Optoma EP771 DLP Projector
I have changed bulbs but still have a blurry line
the light tunnel is collapsing and needs replacing. the part is cheap.
Aug 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Ho do i access the belt on the kenmore 60 series dryer ? therers a 1/4 panel at the bottom . I think my belt is broken
take out phillips screw by lint screen. pull top panel towards you, lift top. remove two 5/16 inch screws on inside of front panel. undo door switch plug on right side at top of inside panel. pull panel up and remove. to remove belt push tension pulley to right and pull belt off. reverse to put back together
Jun 21, 2009 | Kenmore 60172 Electric Commercial Dryer
Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
Jun 02, 2009 | Toshiba REGZA 47HL167 TV
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
Toshiba TP50H50
Hi There!
I am not familiar with this model,however if there are no screws or clips on the inside or side panels, the front would be the place to start. usually right at the bottom front are screws to remove the bottom front panel first. Then the rest will be exposed. Work your way from the bottom up. The screen itself will be last and normally hooks over the top frame. Good Luck, JUS004
Feb 26, 2008 | Toshiba TP50H50 50" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Sony bravia 50 inch projector tv kdf-50e2010
how do you remove the screen from sony kdf 50e 2010 i have removed screws from top and sides of tv but cant see how to release bottom of screen
Nov 07, 2007 | Televison & Video
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
