Question about LG DLE2532W Electric Dryer
Installing an extra exhaust fan
This is in response to your suggestion to install an extra exhaust fan on my LG dryer.
Note that I didn't replace the twisting vent tube until after it blew the second time.
But if a new fan will do it, then I guess I'll try that.
Not sure how to reply with my phone number - I'd rather it not get posted to the forum.
Thanks
Tom
    Genius:
  • 3,587 Answers
Then use this link, and there's a call me feature at the bottom of that page, where you can call my computer for free, by putting your phone number in there.
it's called Grand Central
Posted on Jun 01, 2008
We have a long dryer line to the out side vent... how do we improve drying time... line is clear and we clean the lent from the dryer frequently...also, clean lent after every use..
If you may want to look into installing a booster fan for your vent line.
It can really help in cases such as yours when the vent line is extra long.
Oct 04, 2014 | Kenmore Dryers
Why would my crosley dryer get really hot but the clothes don't get dry
If the dryer is getting hot (the heater element is working) but the clothes aren't drying, it suggests that there is insufficient air flow through the dryer. Remove the exhaust tube from the back of the dryer. With the tube removed and the dryer running, check for hot air (lots of it) flowing out the exhaust vent of the dryer. If there is good air flow, check the exhaust tube for lint build-up or a clog that is blocking the air from flowing through the tube. If there is no air coming out of the exhaust vent with the exhaust tube removed and the dryer running, it suggests that the problem is with the exhaust fan inside the dryer.
Jul 08, 2014 | Crosley CDE6000 Electric Dryer
Exhaust fan just installed not working
Did you have it professionally installed? I would suggest contacting the manufacturer to see if the issue is under warranty. You can find the support page here: http://www.lg.com/us/support-product/lg-LSVC302ST#
Dec 23, 2013 | LG Studio Series LSVC302ST
I have a LG dryer model dlgx3002w not heating.
It sounds like you didn't install the ignitor properly. Try re installing the ignitor, because it's opening the gas valve saying it's hot enough to light, but if it's out of position, it won't create proper combustion.
Nov 23, 2013 | Maytag Neptune MDG6800 Gas Dryer
Dryer heats sometimes and other times it does not. tested heater element and fuses and they were good. replaced both thermostats and it still does not heat well. any suggestions
You did not post make or model, so I can't be certain what technology your dryer employs or it's age. Here is my suggestion... Have you cleaned the lint trap area all the way to machine exit? How about the hose to the outside, is it clean and not bent or restricted? If there is a restriction, the steam cant escape and and it will take forever for the clothes to dry. I'd also check to see if there is air coming out the exhaust. If not, check to see if the fan is clogged with lint, intermittent or missing. If no air flows through the drum, it will keep it hot and moist, and never dry the clothes.
Jun 17, 2012 | Dryers
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Why does the dryer overheat?
First guess is not enough airflow -- See how much air is blowing out the exhaust vent. If it seems weak, first make sure there is no excess lint in the exhaust path (check inside the dryer as well as the exhaust hose). If there still isn't enough air moving, the blower fan is likely loose on its shaft. If the dryer is overheating and you have very strong airflow, then the temperature detectors in the exhaust path are probably not ever telling the heating element it's warm enough. Check for loose wires, or you might have to replace the detector.
Apr 14, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
18' clearance for undercounter????
If it calls for 18", provide 18" minimum. It is for a combination installation and safety. If you install it against recommendationd, you are responsible for safety issues.
Mar 25, 2009 | LG Dryers
LG 50" Plasma makes a popping noise then shuts off
hello my friend, your problem is with the Y or Z SUSTAIN BOARDS if got to feel the stimulus package replaced boths.
Mar 23, 2009 | LG 50PG20 50 in. Plasma HDTV
LG DLE2532W Electric Dryer Logo
51 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
