Question about Candy CDC266 Dryer
Candy CIC60 01 Tumble drier
My candy tumble drier has stopped drying and the clean filter light is constantly on. Cleaned all filter, checked for loose wires can not see a problem any suggestions thank you
  • 3 more comments
  • catfur Jun 04, 2008
    same but no lights on. Sits there making the ticking sound it makes when water container or filter needs cleaning. Have done all this but not helped. Do you know where I can get a manuel for this machine - maybe my son can fix it! Candy CDC266 Dryer - C1C60 Reverse actin Condenser
  • claretmad Jul 13, 2008
    Exactly same problem.  Filter light on, but filters checked and clear. (Candy CIC 60)
  • janine2 Oct 12, 2008
    Same problem, dryer not heating up. Filter light is on but does go off. Cleaned large filter, even vacced out filter in door!!! Removed top and cleaned all the inside around the controls but still not working
  • karenbridges Dec 03, 2008
    I have the same problem filter light stays on even after it was cleaned out
    and dryer does not get hot! help any ideas???
  • Anonymous Mar 26, 2014
    how to change capacitor on candy goc58f
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Posted on Oct 12, 2008
My candy condenser dryer isn't heating up. I have cleaned it and emptied the water canister. The drum is turning ok . just will not heat and all six lights flash after around 15 min.
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
How to repair tumble dryer when is not heating or drying ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Tumble dryer not heating - White Goods Help
Nov 28, 2015 | Candy Dryers
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Jul 16, 2015 | Candy Dryers
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Hi, My candy CIC60 tumble dryer has stopped drying and the empty water light is constantly on. The timer works. I have cleaned all filter,emptied water, checked for loose wires and I can not see a problem....
Tumble dryers are really not around my neck of the woods however I have studdied them just in case they do begin to show up around here. What turns on the light and kills power to the dryer when the water tank is full? A float switch. I bet that float switch is stuck. Probably something simple like that.
Nov 29, 2011 | Dryers
I have a Candy Grand 8g vented tumble dryer. No matter which programme I put it on, it starts drying for a few seconds, then ALL the lights flash and it stops. I have cleaned the filter and do not know...
Its a wierd coincedence I have the exact same problem this morning,and my identical unit is 6 months old.Misery loves company,I will read the on line fault finder manual for this unit and hopefully find an answer
Regards Quiggers in Ireland
Nov 28, 2010 | Candy CDC266 Dryer
I have the Candy C1C60, the "clean Filter light will not go off
I had the same problem, cleaned the whole machine until it was back to show room condition but the light was still on. Turns out my heater had packed in, bought a replacement and fitted it and it down the trick (no light and drying clothes)
Jan 03, 2010 | Candy CDC266 Dryer
Dryer tumbles, trake long time to dry or partly
Check the hose at the rear of the drier, if the hose is restricted even to the vent outside she will not move the air to dry your clothes. Also check the filter and down inside the filter area. Clean it out.
Sep 18, 2009 | Dryers
Candy CDC266 Dryer Logo
1,160 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
