Question about Tally 6312 Matrix Printer
Skip ribbon weld error - Tally 6312 Matrix Printer
2 Suggested Answers
LineMatrix
  • 34 Answers
SOURCE: tally 6218 give skip ribbon weld error
Skip Ribbon Weld
Explanation: This is an advisory message. The message appears when
the welded part of the ribbon is moving across the Hammer Bank.
Corrective Action: None. Wait for the ribbon to finish moving, and the message will disappear.
Posted on Apr 26, 2010
Oven element
model T, either you have a stuck or shorted broil keypad or the relay on the board is welded closed. Try this, remove the back panel behind the control panel. Make sure the breaker is off to the range. Unplug the keypad ribbon cable to the main board. Power the unit back up. You should get an error code. Now if the broiler still comes on you know you have a welded broiler relay on the board. If the broiler doesn't come on..it's the keypad. Catriver.
Sep 19, 2007 | Kenmore 92002 / 92004 Kitchen Range
Weld detect error
Ribbon weld needs to be replaced.
Jul 01, 2014 | Printronix P7010 Printer
Weld not found
On the left hand side the ribbon passes though a "U" shaped sensor. This is your weld sensor, clean any ink from it first then replace it if it continues to fail. Part Number is 254476-001.
May 08, 2013 | Printronix LineJetĀ® P7010 Matrix Printer
WELD NOT FOUND ERROR
Sounds like a failing weld sensor. Clean it first its on the left side, you can see it when the ribbon is out. If that doesn't help replace it.
Tally 6218 give skip ribbon weld error
Skip Ribbon Weld
Apr 21, 2010 | Tally T6218 Matrix Printer
I have lincoln 125 mig welder that seems to want to skip while you are welding I have tried turning up amps, but it still skips. it welds good when it is working but then jumps when the wire does not arc....
Re-adjust your tention wing nut, or make sure you have the correct groove on the feed wheel for the size wire you are using. also, if you are using an extention cord that is to small or to long it will cause it to skip.
Dec 03, 2009 | Welding Tools
It prints the yellow & magenta layers, then skips printing cyan & black (with screeching noise as the ribbon passes) to printing overlay (sometimes skips overlay), but stopped short of ejecting to...
Download the latest copy of the C30 firmware, Fargo created a fix by sending more power to the ribbon sensor. After downloading the new firmware, calibrate the ribbon covering the printer the best you can from light.
Nov 18, 2009 | Fargo Persona C30 Thermal Card Printer
Opening Canoscan case
screws on bottom ease the case off fix ribbon there under the rubber stops then once open your going to want to seal galss back down i recommend jb weld on edges to hold glass in if u dont secure glass when open a month down the road the glass will pop down i had my scanner 16 years since jb welding the glass down you only spot jb weld the glass though
May 05, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Tally 6312 Matrix Printer Logo
91 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
