Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
When is working the air compresor let pas oil to compresion tanks, the rings no broken. can you help my lot tanks. Im gerardo gonzales rios
Sounds like rings could be worn pretty bad. they get like like that after years of working in dusty enviroments...just a guess though. Maybe too much oil in crankcase?
Posted on Oct 13, 2010
MY AC NO WORK
Perhaps 'compreser' is broken. Heve cas, but compreser no gud.
Oct 21, 2015 | Air Ride Management 1998-2003 Opel Astra...
Air is not building up pressure
There may be few causes for this.
1. The piston rings are worn out. If lot of oil comes in your receiver tank ththis is the indication to tell you that the piston rings and oil scraper needs to be changed.
2. The leaf springs strip is broken or worn out. If air is coming out of the suction filter open the compressor head with proper marking check and then fix back the same way you opened it.
3. One of the gasket is damaged or broken. Once again you will find air blowing out from the suction filter.
Aug 10, 2012 | Coleman Powermate 27 Gallon Air Compressor
Nailer bn125a not getting compresion and compresor is working good
make sure hose or fitting that is screwed into tool is not clogged
May 09, 2012 | Air Tools & Compressors
I HAVE A PIECE OF EQUIPMENT THAT RUNS AT 75 PSI. I NEED TO BUY A COMPRESSOR THAT WILL HAVE A DUTY CYCLE OF 50%. HOW CAN I SELECT WHAT SIZE COMPRESSOR I NEED?
That is an extremely high pressure. I would firstly check to make sure that THAT is what you need, then MOST compressors have a regulator where you can adjust the pressure required.
It is not so much the pressure you need as the STORAGE of air that you need for a pressure that high. MOST tanks are around the 20 or so litre. To utilise a tool requiring the pressure of 75PSI I suspect you would need a tank of somewhere around the 2-300 litre size or maybe even bigger. But first just make sure that you DO need the 75PSI you mentioned.
Feb 10, 2010 | Air Tools & Compressors
Ingersol rand p185wir blowing compresor oil out air inlet
expect some oil in the air. I think you have too much oil in your machine OR your rings are worn.
Dec 19, 2009 | Ingersoll Rand Air Compressor Maintenance...
95 5.2 in grand cher. one cylinder low compresion even with new heads doesn"t use oil either like bad rings do
Try a leak down test, similar to a compression test, but fills the cylinder with air and regulates the amount of air escape. This may help.
Dec 09, 2009 | 1995 Jeep Grand Cherokee
I have a honda cr 125 with no compression dp u no wat it is and its a 98 modle
its one or more of the next few things. bad rings, bad head gasket, hole in piston
May 05, 2009 | Honda XR 650 R Motorcycles
Lens is stuck and wont move. on the screen it states "Turn the power off and on again" help pls? Was working just fine and then started with the lens not opening...I opened manuelly and now it wont't take...
I agree that the camera needs to be sent back when this happens.  I have seen people suggest pulling on the lens (a bad idea) and smacking the camera / rapping it upon something (an even worse idea).  Not only will these options often fail to work, they will damage your camera further and void your warranty (leaving you stuck with a broken camera).  If you find a fault in this (or any) camera, DO NOT HESITATE to either send it back or demand a refund in full.  The lens sticking IS A FAULT IN THE CAMERA, not something the consumer should have to fix on their own.
Also, for the record, if Solution #1 (posted by "geragodina") is really a copy/paste of a LiveAssist Chat, please be aware that "Patrick" was not an actual person, it was an AI chatbot (if you need proof, try visiting jabberwacky[dot]com).  I have been writing AIML for various chatbots for years, and am amazed that this site charges for "Live" Assist Chat when they are using scripted chatbots.  Save your money and ask real people.  Remember, chatbots are only as smart as the people who program them.
Dec 31, 2008 | Sony Cyber-shot DSC-W170 Digital Camera
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
