Laptop when I start my laptop, the screen says Press ESC to change boot order Press to enter Setup, Press to boot from LAN..... When I try any of thes option, nothing happens. This just started Sat morning after I unplugged the laptop for a storm on Fri. night. Any suggestion..... Jerie
    Genius:
  • 3,587 Answers
Hmmm..yes..sounds like your bios is fried..
you have the recovery disk anywhere? or a operating system disk?
Posted on Jun 01, 2008
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 05, 2013 | Dell Latitude D800 Notebook
CD Drive will not allow boot
Change the boot order
Feb 03, 2013 | Computers & Internet
How to get to boot chooer on tne m700 starts
Hi.
  1. Turn on the computer. When the Compaq logo displays, press F10. Or,
  2. During Power On Self Test (POST), and after the memory check completes, press F10 as soon as you see a small white square flashing on the top right corner of the screen.
  3. In the computer setup, use the right arrow to move the selection to the Advanced menu.
  4. Use the down arrow to move the selection down to Boot options, and press Enter. The Boot options menu pops up with four boot order options.
  5. Use the down arrow to move the selection.
  6. Press the left arrow to change the order of Notebook.
  7. Press F10 to accept the change.
  8. Press ESC to jump back File menu, and then move the selection down to "Save changes and exit".
  9. Press Enter. If asked to save changes and exit, press F10.
On some laptops you can change the boot order by tapping the F12 key as the computer starts up.
Regards.
Jul 16, 2011 | Compaq Armada M700 Notebook
DELL latitude 100l, someone disabled all boot devices then set config / administrator password. Please help
Boot Priority on Dell Latitude 100L
  1. Turn On Your PC
    Have you ever noticed the messages that pop up on the screen as soon as you turn on your PC? These messages tell you a key combination you can press to enter "Setup" or the "BIOS." Watch your screen and see if you can read what keys to press.
  2. Press the Keys to Enter Setup Mode
    If you did not see a message telling you what keys to press, try tapping the following possibilities as you turn on the machine:
    • Esc
    • F2
    • F12
    • F10
    • F1
    After pressing Esc or other key, you will most likely see instructions telling you how to enter "Setup Mode". Follow those instructions.
    tip.gif On some computers, you must hold down the key before you press the power button to turn on the computer. For example, if you are converting a Toshiba laptop to a Linux Workstation, you must hold down the Esc key and then press the power button. The computer then asks you to press F1, and you can then set the "Boot Priority."
  3. Using the Arrow Keys, Choose the "Boot," "Boot Order," or "Boot Priority" Option
    The menu of choices you see will be different for different kinds of computers. Remember that the choice you want is the "Boot" order or "Boot Priority." On some computers, this is called the "Start Up Options" or "Start Up Sequences." You are going to change where the PC will look for boot information when it starts up. (CD-ROM, HARD DRIVE/HDD, LAN, FLOPPY, USB). If you wish to boot from your Hard drive, then select it as your First Priority.
  4. Using the instructions on the screen, save your settings and start up your PC. The PC must boot from the HDD. Regrds
Jul 01, 2010 | Dell Latitude 100L Notebook
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
Can't boot up my HP XE4100 laptop
press hard disk and boot the windows
Apr 01, 2009 | Computers & Internet
Wont start up
Try pressing escape and setting up the local hard disk (C:\) as the boot media. This (if there is an operating system installed) will boot to the hard disk. Try that and see if it works for you bud.
If that doesn't work, try putting your recovery disc into the CD-Rom drive then restarting. It should load up the CD's software and you can go from there.
Try these solutions and see if they work, If they don't, simply reply and we'll go into a little more detail with figuring out what happened.
Sep 13, 2008 | Compaq Presario X1000 Notebook
Unable to get to CMOS using any of the 3 methods
This machine is one of the first "legacy free" models which means there are no BIOS options to change. All settings and resources must be assigned by the OS.
For details, please check the "legacy free" FAQ on MS Knowledge base.
If you are trying to access the BIOS to change boot order so that you can boot from a CD, hold down the 'c' key during POST/boot. This will case your laptop to boot from CD-ROM.
Apr 09, 2008 | Toshiba Satellite 5005-S504 Notebook
Computer will not run windows xp anymore?
Hello, do you have a floppy disk or anything in the drive? also check the boot order in the BIOS (F2) and see can your laptop see the hard drive. What is your Laptop, What is your version of Windows/Linux?
Feb 19, 2008 | Computers & Internet
Prosario V2000 boot problem
This means that there is some component was not fixed well.
this error means: " press esc to change boot order"
"press F10 for setup press F12 to boot from lan"
with 2 beeps " that the system cannot find hard drive:
fixed every thing: and try this. if prompted to go setup , continue and find "load bios setup default and then save and exit.
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
