Question about Samsung DVD-V4600 DVD Player/VCR
VCR shows tape is playing, but no picture or sound.
  • 597 Answers
First, you need to check if the cables are properly connected to the television. Then you also check if you have your television on the appropriate channel that is to work with the DVD player/VCR combo for instance the AV channel. Then you can further try to change the cord used in connecting the DVD player to the television, if it does the same, then the problem is most likely from either the DVD's Audio Video port or from the Televisions Audio video port.
Have them both checked to detect which is faulty, and replace with the same type of port where fault is detected.
Take care and good luck
Posted on Oct 13, 2010
2 Suggested Answers
  • 1768 Answers
SOURCE: VCR has sound but no picture
Your video head are dirty
Needs cleaning
> use denatured alcohol and shamos sticks
> clean tape guides also / they will have residue that will transfer to the video heads.
> be careful not to snag the heads.<<< very delicate
> professional should do the cleaning
hope this helps.
Posted on May 22, 2008
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
Recording from VHS to DVDR was going fine,then I stopped getting a picture. DVD player is fine plays back recordings etc. However tape player starts to play shows picture then stops showing video and...
Possibly dirty video heads. I would suggest that you run a head-cleaning tape through the VCR deck to shift surface dirt off the heads. If that doesn't work, or it sort of works, but not satisfactorily, unplug unit, carefully remove top cover, and with the VCR deck in view, gently clean the heads with a soft cloth or special cleaning stick (these look like flat q-tips but are intended for VCRs - available from electronics/hobby stores) and some alcohol (methylated spirit will work if that's all you got - but isopropyl alcohol is recommended - available from the same places as the sticks) clean the guides (gently so as not to disturb their alignment) clean the pinch roller/capstan shaft - CTL (on the right-hand side of the drum) and FE (left side) heads as well. The whole tape path should be carefully cleaned. Refit top cover (carefully), plug unit back into power, wait until it completes its startup/loading procedure, then put a tape in. You should now have a playback picture with the sound. You only need to do this as required if head-cleaning cassettes don't work properly.
If none of the above cures your problem, then the heads are abraded/worn - let's hope that isn't the case here. This model does not use a built-in head cleaner.
Feb 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Vcr sound but no picture
After checking the connection, played a pre-recorded tape and the picture was displayed gradually. After about 5 mins picture was completly restored. Lost of picture was due to dirty tape heads.
Mar 22, 2009 | Panasonic TH37PX60 37 in. Plasma...
VCR playback sound and pciture don't match
That is a tape path issue. The new VCR has the problem, usually the guide post for the tape sticks out when it shouldn't making the sound late for the picture because the gap between the video head and audio head is wrong.
Mar 31, 2017 | Philips Magnavox 20MC4304 20 in....
Won't play tapes, just stays on the blue screen
ok. what you need to do it hit the side where the tape goes in...start out slow and then gradually hit harder and harder...not too hard though...because it sounds like a hardware jam...you need to unjam it by shaking it up a bit.
Jun 28, 2008 | Canon Elura 100 Mini DV Digital Camcorder
No picture
Sounds really broken. Unless you can find a replacement DVD drive for low money , you may have to junk it.
Dec 12, 2007 | Sanyo DVW-7000 DVD Player/VCR
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
VWM-950
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
545 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
