Question about Symbol MC9090-G RFID Handheld Barcode Scanner
Whenevr i ON this device , it directly go to connecting place.. but it not connect with host computer . so i want see this setting and IP and all.. but here dont have any options, so how i can exit and how to see setting..
  • 132 Answers
When your comp recognizes a device it usually shows several changeable settings start from ther.
Posted on Oct 13, 2010
How can I get a second hand Mitel 5215 to accept an IP address?
Your phone needs an IP address in order to communicate. Normally, it asks a "host" for that IP. You need to be connected to the internet for it to connect to the normal host, and your router should be willing to give it that IP address. "DHCP" is how devices ask for and get an IP address.
May 11, 2015 | Mitel 5215 IP Phone
Tip
Networking Issues
Problem: Network Cable Unplugged
Description: Don’t take this message literally - there are many causes besides not having a cable physically plugged into the network card. The message really means that the network card doesn’t detect a live link to another device on the other end of the cable.
Possible Solutions:
Download and install the latest network card driver program.
Check the cabling - a bad cable will prevent link detection. Substitute a cable that’s known to be good.
Check the link lights on the device on the other end of the cable, whether it’s a hub, switch, router, or a NIC in another computer. It should show a live link to the NIC. If it doesn’t, try a different port.
Auto-detecting speed and duplex mode can be unreliable. Set them manually. Most routers and switches use 100Mb, full duplex. Hubs can only use half duplex.
Problem: Renewing a DHCP lease fails, with error message “An error occurred while renewing interface <name>: The system cannot find the file specified.”
Problem: Network connection configured to obtain an IP address automatically has IP address 0.0.0.0
Solution: Make sure that the DHCP Client service is running:
Right click My Computer, and click Manage.
Double click Services and Applications.
Double click Services.
Double click DHCP Client. If the Service status is Stopped, click Start.
Set the Startup type to Automatic.
Thanks to Lightcap, who suggested this fix in a news group message.
Problem: Network Connection Has IP Address 169.254.x.x
Description: The network card is configured to obtain an IP address automatically, and it’s connected to a network with a DHCP server: hardware router, another computer running Internet Connection Sharing, cable modem, DSL modem, etc. But it gets a 169.254.x.x IP address, which indicates that it can’t communicate with the DHCP server:
Possible Solutions:
Connect the computer using a different Ethernet cable or hub/switch/router port.
Download and install the latest firmware for the hardware router.
Disable XP’s Internet Connection Firewall <../xp/ic_firewall.htm> on the local area network connection.
The card is configured to automatically sense network speed and duplex mode, but auto-sensing is failing. Configure the speed and duplex mode manually. For example, most switches and routers use 100 Mb speed and full duplex. To make the settings, right click the network connection and click Properties | Configure | Advanced.
Un-install the network card and move it to a different slot.
If you have a cable modem connection, turn off the computer, turn off the cable modem, and wait a few minutes. Turn on the cable modem, and then turn on the computer.
Error Message: An error has occurred while trying to share <filename>. The Server service is not started. The shared resource was not created at this time.
Solution:
To start the Server service:
Right click My Computer and select Manage.
Scroll down the list of services and double click Server.
Click the Start button.
Click Apply and OK.
Problem: Computer A Can Ping Computer B, but not Vice Versa
Solution: This is almost always caused by an improperly configured firewall on Computer A.
Problem: One Computer Can’t Access Some Web Sites, but Other Computers Can
Solution: Look for the Windows Hosts file on the problem computer:
Windows 95/98/Me: C:\Windows\Hosts
Windows 2000: C:\WinNT\System32\Drivers\Etc\Hosts
Windows XP: C:\Windows\System32\Drivers\Etc\Hosts
Open it with a text editor and you'll probably find lines with the names of the sites that you can't access. Delete those lines, save the file, and try again. If those are the only lines in the file, delete the file. Be sure to save it with a file name of just Hosts, with no file type. If your editor saves it as Hosts.txt, rename it to just Hosts.
The Hosts file can be created by "web accelerator" programs that store name-to-IP address translations. This might speed up access by a tiny amount, but it causes problems when a site's IP address changes.
Problem: A shared disk or folder doesn’t appear in My Network Places
Description: The disk or folder is shared correctly on another computer, but it doesn’t appear.
Solution 1: Click Add a network place and follow the prompts to add it. Browse to it through Entire Network, or specify the path name using the form \\computer\share.
Solution 2: Click View workgroup computers, then click the computer that has the shared disk or folder.
Problem: XP's Network Setup Wizard Says That No Network Card Is Installed
Solution: XP's Network Setup Wizard sometimes fails to recognize an installed and working network card. This is because the NIC's driver program doesn't respond correctly to all of the queries that the Wizard makes when it's looking for a NIC. Configure the card’s TCP/IP properties manually. Here’s how to do it for Windows 95/98/Me <../ics/icsclient.htm>, Windows 2000 <../ics/ics_win2k_client.htm>, and Windows XP <../xp_ics/clientwiz.htm>. Then set the workgroup name to MSHOME.
Problem: Windows XP takes a long time to open a shared disk or folder on a computer running Windows 95, 98, or Me
Description: This is a different problem than My Network Places taking a long time to open <slowbrowse02.htm>. This problem occurs after you double click a shared disk or folder.
Possible Solutions:
Disable searching for scheduled tasks
This Microsoft Knowledge Base article <http://support.microsoft.com/default.aspx?scid=kb;en-us; Q245800> describes a bug in Windows 2000 Professional that might also exist in Windows XP. Disable searching for scheduled tasks by deleting this registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\
CurrentVersion\Explorer\RemoteComputer\NameSpace\
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
· Delete stored network passwords
1. Click Control Panel | User Accounts.
2. Click your user name.
3. Click Manage my network passwords.
4. Click each entry and click Remove
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
Hi ..I can't connect to my yahoo messnger..And it says here's the problem..hope u can help me.. Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw]...
can you get an internet connection?
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in yahoo.com)
check your firewall settings make sure yahoo is allowed
click start type in cmd press enter
you should have a black screen you are in dos mode
type in ipconfig
you should see all of your connection details
type in your default gateway adress into your browser (search engine)
hope this helps you
Oct 18, 2011 | Yahoo Messenger
Windows xp installed in VirtualBox as guest through Host Ubuntu 9.04 eth0 and eth1 shown cable plugged. internet connection established in Host but not working in Guest xp
There could a few things that could be preventing internet connection to your host windows xp.
Check these out:
-Dont follow these an order LOL
1) make sure the windows firewall is not causing the problem
a) do a test by turning it off. click on "Start" click on "Run" and type "Firewall.cpl" and turn it off. then see if you get a internet connection.
2) maybe you have set to "obtain an ip automatically"
a) click on "start" then right-click on "My network places" click on "view network connections" right-click on "Local area connections" slect propeties" then scroll down till you see "Internet Protocol TCP/IP" and click on "obtain an ip automatically"
3) when you open up VirtualBox check that you have it set to "NAT" i have mine set to "Bridged Adapter" so my virtual machine can get an ip from my router.
4) make sure your router isnt blocking in some way your virtual machine...maybe your router has a firewall.
5) also maybe host's firewall is causing the issue
let me know how it goes.
Oct 26, 2010 | Dell Ethernet Card Network Adapter
Transfering data between two hp laptops
hi,
Please find below the possible ways of transferring the files between two laptops,
  • Create to share folders if its connected via Lan with cross cable and transfer the data.
  • Turn on your Wireless and transfer the data
  1. Right-click My Network Places and select Properties.
  2. Select "Create a new connection (WinXP)" or "Make New Connection (Win2K)" to launch the New Connection Wizard.
  3. Select "Set up an advanced connection."
  4. Select "Connect directly to another computer."
  5. Choose Host or Guest configuration (configure one of your computers for each role).
  6. Complete the wizard depending on whether you're setting up the Host or Guest computer. Make sure you select the IrDA port as the connection device.
Thanks
Oct 23, 2010 | Iomega Computers & Internet
Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED] *** 'COMPONENT_TYPE_WININET' value:...
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
Aug 16, 2010 | Yahoo Messenger
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
How do i connect to xbox live with a router
Shared connection with a modem and a router
1. Turn the modem off, and then turn it back on. Then turn the router power off, and then turn it back on. This is also known as power cycling the modem and the router.
Power cycle the modem first, and then power cycle the router. To power cycle these devices, you should follow your manufacturer’s specific instructions. Here are some general steps:
a. Remove the power supply from your device.
b. Leave the device unplugged for 15 to 30 seconds.
c. Reattach the power supply to the modem by following the device manufacturer’s instructions.
d. Wait several minutes for the device to start and to establish a connection with your broadband provider.
e. Verify that the modem shows the appropriate power and Internet connection indicator lights by following the manufacturer’s instructions.
2. If power cycling your modem and router does not resolve the problem, try connecting the Xbox 360 console to Xbox LIVE by using the modem only. This eliminates any configuration problems on the router. If this setup works without the router, there is probably a configuration issue with the router. See the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
3. Verify that your router's Dynamic Host Configuration Protocol (DHCP) service has been enabled. DHCP enables the router to assign IP addresses to the computers and consoles on your network when you go online. If you need help with this, see the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
4. If you manually entered an IP address, gateway, subnet mask and/or DNS servers in the Network Settings area of the Xbox Dashboard , verify that it they are correct. At this point, you can also set your IP settings to Automatic. To do this, follow these steps:
a. Move to the System area.
b. Select Network Settings.
c. Select Automatic.
5. If your ISP requires Point-to-Point Protocol over Ethernet (PPPoE) settings, try connecting to only the modem after you enter these settings in the Network Settings area of the Xbox Dashboard. Network Settings area of the Xbox Dashboard.
Note Some ISPs may require Point-to-Point Protocol over Ethernet (http://www.xbox.com/en-US/support/connecttolive/xbox360/resources/glossary.htm#ethernet) (PPPoE) settings, This means that you may need settings such as a username and password in order to gain access to your ISP’s network. If you are unsure whether you have to enter these settings, please contact your ISP support group. At this point, if you can connect directly to the modem, see your router documentation to configure the PPPoE settings correctly on the router.
6. If you are receiving an IP conflict error in the More Info section of the Xbox Dashboard, turn off all devices on the network. Try to connect to Xbox LIVE with only the modem and Xbox 360 console connected.
If this works, there may be a configuration issue on the router’s Dynamic Host Configuration Protocol (DHCP) server. DHCP enables the router to assign temporary IP addresses to the computers on your network when you go online. If you need help with understanding DHCP or the configuration, see the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
Shared connection with a gateway device (combined modem and router)
1. Make sure that the gateway is turned on. A gateway integrates a high-speed Internet modem with a router.
2. Verify that there is network activity by looking for the sequence of blinking lights on your gateway that generally indicate Wide Area Network (WAN), Local Area Network (LAN), and connected power status.
Note These names will vary from model to model.
3. Turn the gateway device off, and then turn it back on. This is also known as power cycling the gateway. To power cycle this device, you should follow your manufacturer’s specific instructions. Here are some general steps:
c. Reattach the power supply to the gateway by following the device manufacturer’s instructions.
d. Wait for the device to start and to establish a connection with your broadband provider.
e. Verify that the gateway shows the appropriate power and Internet connection indicator lights by following the manufacturer’s instructions.
4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Be sure that this address is correct, or set your IP settings to Automatic in the Xbox Dashboard.
5. If you are receiving an IP conflict error in the More Info section of the Xbox Dashboard, turn off all devices on the network. Try to connect to Xbox LIVE with only the modem and Xbox 360 console connected.
Shared connection with Microsoft Windows Internet Connection Sharing
1. Verify that you can surf the Internet from your PC. If you cannot surf the Internet, there is probably a problem with your Internet connection. Contact your ISP for support.
If you are using a USB modem to connect to the Internet, the modem will be listed in the "Dial-up" window as the connecter that you are sharing and that you have configured. To verify that Internet Connection Sharing configured it correctly, use the following steps:
a. Click Start, and then click Control Panel.
b. In Control Panel, double-click Network Connections.
c. Right-click your broadband connection, and then click Properties.
d. In the Properties dialog box, click the Advanced tab.
e. Click to select the Allow other users to connect through this computer’s internet connection check box.
f. Click OK.
Ethernet Properties
2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer.
3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK.
4. On the View menu, click Tiles.
5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation.
6. Enter manual settings in the Xbox 360 Dashboard for IP address, subnet mask, DNS address and gateway and test the connection: To edit the settings:
a. In the Xbox 360 dashboard, move to the System section.
c. Select Edit Settings.
d. Enter the following:
• IP Address : 192.168.0.2
• Subnet mask : 255.255.255.0
• Default Gateway : 192.168.0.1
• DNS server (Primary): 192.168.0.1
• DNS server (Secondary): 192.168.0.1Xbox 360: Test Xbox LIVE connection fails at IP address
Dec 06, 2007 | Microsoft Xbox 360 Console
Symbol MC9090-G RFID Handheld Barcode Scanner Logo
80 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
