Question about Fisher and Paykel Washing Machines
My machines keeps stopping every cycle it goes thru and i have to push start every ten minutes so it carrys on with the wash please help it takes me a day to do a load.
  • stormlyboo Oct 13, 2010
    the model number is LW035-F that's what is written next to model number on the sticker you referred to. It's a top loader and when it's half way through each cycle it stops and beeps and all the lights corresponding to the unfinished cycles flash until you press the start/pause button then it resumes. When it reaches the final spin however it runs the complete cycle and finishes just fine.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now I need the model number of the machine which is on a sticker at the back of the machine top left.Does the machine beep and show an error code as in lights on or something in the display?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 13, 2010
Testimonial: "Great help!! Assisted me in getting my washing machine going"
  • 7 more comments
    hi
    model number is LW035-F. it beeps and the lights flash untill i go and push start so it continues the wash
  • luisa_sgro Oct 13, 2010
    Hi just read your last posting.Is your machine a FISHER@PAYKEL front loader.Or is it another brand and is it a front or top loader?Please reply with additional information .
    I've just run a cycle to double check. The hot and cold lights are flashing at the same time. Is this some type of error code?
    Hi just read both postings.Now you mentioned in your last posting that the hot and cold lights are flashing ,If this is correct then what wash temp have you selected,is it cold, warm or hot?Also have you a manual water selection option on your machine or is it automatic?Both hot and cold lights flashing on a FISHER@PAYKEL machine usually indicates a problem with water coming into the machine.Please reply with additional information on the questions and I am sure we can rectify this fault.
    Hi me again.Just a couple of questions as I am having trouble finding your model number in my service manuals.How old is your machine?And is there a name on the front control panel like ,Gentle Annie or smart drive --etc--?Sorry to ask these questions but I need this information to accurately diagnose the fault with your machine.Thanks for your patience.
    We only ever use cold wash, and yes it does have manual water temperature controls and water level controls.
  • luisa_sgro Oct 14, 2010
    Hi just read your last posting.Now I am sorry to ask these questions again but unfortunately I need some more information on your machine.The questions that need to be answered are -------1---How old is your machine approximately? --2---Is there a name on the front panel --eg Gentle Annie ,smart drive ---etc---?Please reply on these questions and I look forward to helping you repair your machine.
  • stormlyboo Oct 14, 2010
    Hi there, Thank you for your help, you were absolutely right about the water not getting through. I just had to swap over the solanoid inlet valves and now it's all go. Thank you agai, wouldn't of figured ot out without your help.
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Stops at spin cycle
sounds like ur door switch is either bad or not getting pushed in it should have a lil arm on the door that goes in a hole and pushes a switch this is a safety switch so arms dont get broke my brother n law did this it can happen hes a bright one but turn it on the spin cycle and get a screwdriver and push the switch in and see if it starts if not take switch off and unhook wires unplug unit first and check continuity thru he switch it should have continuity thru it when switch is pushed and not when the switch is not pushed inp.s. they can be a pain to get to sometimes
Feb 24, 2010 | Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water keeps flowing does not stop---does not go thru cycles
You probably pinched the water fill hose that comes up from under the tub when you closed the cabinet. Also make sure it is free from trash in the bottom of the tub and that it is tightly connected to the water level switch.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
238 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
