Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
CLOTHES WASHER WASHER FILLS WITH WATER AND NOTHING ELSE HAPPENS?
    Genius:
  • 1,028 Answers
Ck lid switch on new models left rear under top also might try tightening hinge screws left side may even need to adjust lid hinge left side underneath top push back on lower portion slightly this will help it to engage switch better
Posted on Jun 02, 2008
Machine fills with water , then enters wash cycle without the agitator doing anything
on the top of washing machine there is a slot where the rinse relay is located,this inexpensive part is usually the problem.turn washer off and remove the two screws inside your washer,take a good look at the part yo u can usually repair with tape.
Mar 10, 2013 | Kenmore Washing Machines
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
How to repair a new washes etw4400 when it fills with water and nothing else happens
You will have to drain the water first by putting your drain hose into a bucket, out a door, etc, or use a shopvac (take clothes out first). This washer has a broken agitator belt. If it is new, call a repairman as should be under warranty.
Jun 16, 2012 | Estate ETW4400VQ Top Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Machine will not work and flashes 12 minutes
remove bottom cover look for tech sheet usually on right side of cabinet at bottom fh is usually a water fill issue drain may be siphoning water may be slow filling or bad flow meter flow meter may be harder to diagnois but try tapping lightly with screwdriver (it's the round object left side with 2 small hoses attached ) slim chance may be pressure switch left side rear corner
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water backs up into washing machine after washing a load.
check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer filled with water then stopped
Same problem- quick fix- to release door anyway. Found the service manual online...First unplug power cord and remove bottom front panel. Reach underneath on the right side of the machine- there will be a white round plastic disk that you can pull downward to release the door lock and remove your wet clothes. I found a pen lodged inside which may have caused the 'glitch'. When I ran it again it did the same thing and locked at the same place. The service guy had to replace the door lock mechanism to permanently fix the problem.
Apr 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer fills up but won't agitate
get your screw driver and lets start.. first unplug the machine from the outlet, you have to access the water level sitch so remove the tab and there is the bandidt, knock him with the screw driver and if this not funcion replace it..good luck I dont tell you to check the thin hose in the water level sitch becouse you said its fill all right.
Aug 06, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
