Question about Theater Research TR-502 5.1 Surround Sound System Shelf System
How to hook up to the surround sound to the cable, blue ray, and TV
  • 11,800 Answers
This very simple audio system can be connected to just one unit at a time - it has just a single input set of connectors - and the source must have the full 6 connectors. Because of that you can't connect it to a tv - not a single one has those connectors.
For the rest just buy 3 2-headed RCA connector cables and plug them to the back of the BR or the cable box by matching the colors on the audio jack at the HT and the source - you can't plug them incorrectly, the colors are very distinctive.
BTW don't expect great performances, this is a very simple, low cost 5.1 audio set.
Posted on Oct 13, 2010
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
I bought a insignia plasma tv and a panasonic surround sound with blue ray. Both were open box and no manuel. I hooked up the surround sound and it works good with the blue ray. I can not get it to work...
Basically, you have to use the output audio from the TV to go to the receiver.
On the TV, there should be a red and white audio output jacks for left and right. Or, if the TV has it, the best audio output to use for surround sound is optical output. You'll have to buy a optical cable for this.
Sep 28, 2009 | Televison & Video
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
218 people viewed this question
Top Theater Research Audio Players & Recorders Experts
David Payne
David Payne
 Grubhead
Grubhead
Tom Chichester
Are you a Theater Research Audio Player and Recorder Expert? Answer questions, earn points and help others
